Old 03-04-2022, 04:47 PM   #1
dma05
dma05's Avatar
Drives: 2011 Camaro 2SS/RS
Need help locating bolts - Rear Upper Control Arm
I all new bolts to replace when doing my suspension upgrade soon, but it looks like the bolts for the Rear Upper Control Arm at bushing is discontinued. I called GM and ACDelco and they said they don’t have anything listed to replace it, but that it is definitely discontinued.
Anyone have any ideas where to look? ARP?
Here is the GM part number: 92138935
I have the bolt info: M14 x 2 x 60
I’m guessing I just may need to go to my local bolt store and find it?
Thanks for any help or ideas.
Allen
2011 Camaro 2SS/RS
dma05 is offline   Reply With Quote
Old 03-04-2022, 05:17 PM   #2
gtstorey
Reuse the existing with loctite. Mine has been apart multiple times with no issues.
If you buy a bolt from bolt supplier it probably should be at least a grade 10.9. I don't remember if that particular bolt has a flanged head, but that will be particularly hard to find and you may need to get washers.
Old 03-04-2022, 05:34 PM   #3
dma05
dma05's Avatar
I went to my local bolt store, “King Bolt”, and got the same size bolt but had to get washers. These are 10.9 grade and both bolts were the same cost as 1 GM bolt. Once I get the old ones off, I’ll determine if they need to be replaced or not.
Seems like more and more parts for our 5th Gen’s are being discontinued. Sad.
Allen
2011 Camaro 2SS/RS
Old 03-04-2022, 06:05 PM   #4
Omega
Drives: G8
Hardware store bolts aren't going to last. Goto McMaster Carr, they have exterior grade hardware
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-06-2022, 03:17 PM   #5
dma05
dma05's Avatar
I don't know much about bolts, but if the grade 10.9 matches the factory grade, isn't that the same exterior grade?
Once again, I don't know much about bolts, so I'm looking to understand the difference. Plus, this is a specialized small bolt store I went to, not a hardware store like Lowes or Home Depot.
thanks for the help
Allen
2011 Camaro 2SS/RS
Old 03-06-2022, 04:01 PM   #6
Omega
Drives: G8
Grade is the strength, I would go for the "black ultra corrosion resistant - black" basically what the OEM bolts are coated in. The zinc, or usual home Depot hardware will rot out pretty quick
Old 03-06-2022, 04:35 PM   #7
gtstorey
It may get slightly rusty but it won’t “rot out” in California.
Old 03-06-2022, 04:37 PM   #8
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
lol, They are not going to rot out pretty quick. Even if you are in salt, the coating will start to degrade but they won't be junk. The strength, 10.9 is the most important. As gtstorey mentioned, the old ones can certainly be reused along with some Loctite. They are not single use bolts.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is online now   Reply With Quote
Old 03-06-2022, 05:54 PM   #9
dma05
dma05's Avatar
Thank you everyone for helping me understand. I guess I didn't think about the coating of the bolt. That's why I love this forum, you learn something new all the time.
Allen
2011 Camaro 2SS/RS
Old 03-07-2022, 12:17 PM   #10
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
In stock here?
https://www.gmpartsdirect.com/oem-pa...-bolt-92138935
hesster is offline   Reply With Quote
Old 03-07-2022, 02:31 PM   #11
dma05
dma05's Avatar
Originally Posted by hesster View Post
I went to order from there, but their shipping was $18!! So I ordered from Chevy Parts which has the same looking website and it showed available. They wrote me back right away and said they part is not available and won't be. They refunded me as well.
Allen
2011 Camaro 2SS/RS
Old 03-07-2022, 02:41 PM   #12
cdb95z28
cdb95z28's Avatar
Try gmpartswarehouse.com. Their shipping rates are the most reasonable I have found.
Old 03-08-2022, 08:04 AM   #13
hesster
hesster's Avatar
Keep letting us know your progress my Man.
It can be a frustrating process that tests your patience, and sometimes I just walked away and had a beer.
Or 3.
Then get back at it.
A tip for you I used was to ensure everything was torqued was paint stripes (see 1st image below).
This also allows a sense check every year to assure nothing got loose after beating on it
Old 03-09-2022, 08:20 AM   #14
kevint
Drives: 2013 1SS
Or 3.
I also drew a line on the socket so I didn't have to remove the gun to check.
kevint is offline   Reply With Quote
