Old 03-07-2022, 05:55 AM   #1
BjornA83
Drives: Camaro SS/RS 2SS 2010
OEM differential bushings
Just bought my 2010 ss/rs and found out that the differential bushings are
completely worn out. I'm having a hard time finding new oem ones.
Talked to a parts guy that said gm only sells those as a whole package with the differential itself. Does anyone have a part number i can search with?
All i find when googling is poly aftermarket ones. I want the oem ones because i aim to daily the car.
BjornA83 is offline   Reply With Quote
Old 03-07-2022, 07:20 AM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Curious why you want OEM? That's one of the hardest suspension mods to do on this car, might as well upgrade.
FasNuf is offline   Reply With Quote
Old 03-07-2022, 08:25 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
and I'm sure it will be easier to install poly bushings than factory.
Old 03-07-2022, 11:04 AM   #4
kevint
Drives: 2013 1SS
From the videos I've seen, it's removing the original steel jackets that's the problem. I haven't done it myself to confirm, though.
kevint is offline   Reply With Quote
Old 03-07-2022, 07:20 PM   #5
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Hendrix offset differential bushings! Eliminate wheel hop and not worry about busting axles, especially if you ever lower it.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 03-07-2022, 07:27 PM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I thought I read that these Were closer to stock then others, i am assuming he doesn't want to go with one of the more common bushings because of the NVH .
I probably will go with the Hendrix when the time comes to replace them, I am just worried about the NVH myself.
https://whitelineperformance.com/pro...56-bushing-kit
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-07-2022, 07:34 PM   #7
BjornA83
Only heard bad things about poly bushings.
They are hard so the car crashes and is generally shit to drive in traffic.
they squeak & they wear out really fast.
Also they are hard to install since you have to remove the steel jackets from the oem.
Poly might be better if you track or drag race the car. But for everyday driving oem seems far superior. Exept i can't find the part
Old 03-08-2022, 07:53 AM   #8
CamaroCracka
It is, but polys slide right in and I can only imagine that putting the factory bushings back would require you put them in the freezer overnight and beat them in, or press them in if you have a press.
Old 03-08-2022, 08:17 AM   #9
ABM2SS
Drives: 2010 SS M6 ABM
The OEM Bushings are not easy to remove. I showed what I did to remove mine at the link below.
https://www.camaro5.com/forums/showt...=598332&page=2
The aftermarket bushings that I used transmit a little more vibration and seem a little firmer, but I am happy with them.
ABM2SS is offline   Reply With Quote
Old 03-08-2022, 09:20 AM   #10
gtstorey
Poly may have the problems you mention for "moving" parts in some cases but not nearly as bad for non-moving parts like diff bushings.
Old 03-08-2022, 11:14 AM   #11
demonspeed
demonspeed's Avatar
Drives: Camaros
I’ve never had problems with poly bushings, but my tolerance is likely higher than most. With my 5th Gen I’ve skipped poly and am all solid aluminum or rod ends. I love how connected it feels.
10/13/22: 1100
Old 03-08-2022, 11:38 AM   #12
eLeSthree
Drives: 2011 Camaro SS 6sp
It's not as bad as described, but you definitely feel more driveline vibration.
You might be better off buying a lightly used SS diff.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-08-2022, 08:02 PM   #13
BjornA83
Thank you and thanks to all the other people for your responses.
Found out now that GM only sells the oem bushes as a part of the whole diff case.
So i decided to go with poly bushings instead. Hopefully they are ok. Seems like some of you are happy with them anyway.
Old 03-08-2022, 08:02 PM   #14
diddies
Drives: 2013 ZL1
I went and did all my rear suspension over the last couple of weeks by changing the cradle to solid (went with AFE as they were the only ones I could find that were in stock), BMR trailing arms and toe rods, and went with a coilover set. Used AFE magride deletes and have been working fine. Also did the rear sway bar.
I have replaced the struts twice and tired of footing the bill. Only 1 went out this time, but it has the oil caked on everywhere in the wheel well. The cradle was actually pretty easy. However, I couldn't bring myself to doing the differential. I am going to be looking for a shop to do those soon.
diddies is offline   Reply With Quote
