03-08-2022, 04:27 PM | #1 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
SmoothBoost…who’s running one?
http://www.smoothboost.com/
Anyone running this? I’m leaning towards giving it a try. Being able to dial the boost down for the street and then right back to race mode with the turn of a dial sounds good to me. I’m too lazy to swap pulleys all the time so I end up with just a bit too much power on the street..
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
03-08-2022, 05:20 PM | #2 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Oh no. Mods to remove power :s
I want to play with an electric blower sometime. I think PC makes one.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
03-08-2022, 05:33 PM | #3 |
It’s a lot more than that. It lets you dump the boost if you have an alarm. It lets you avoid large cam idle issues due to lack of vacuum. Dialing down power for street use with no pulley change is the cherry on top.
03-08-2022, 06:58 PM | #4 |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
A bit too much? Lol
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror |
03-08-2022, 08:12 PM | #5 |
Probably no such thing as too much HP… but there is on street tires! That’s for sure.
I’m equally pumped about getting about all the other cool stuff it can do though… although I’ll probably need something like a Holley ECU to really take full advantage of it.
03-08-2022, 09:41 PM | #6 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Why not just limit torque per gear in the trans tune? Then your throttle won't open all the way and that will limit boost.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
03-09-2022, 05:34 AM | #7 | |
My brother is buying one for the 2650 in his Z06 too and will be tying it into his Holley Dominator ECU so it’ll dump the boost if he ever runs lean, so that’s a cool feature too.
03-09-2022, 07:23 AM | #8 |
The boost dump for lean AFR is definitely a nice feature.
2016 NFG 1SS A8
03-09-2022, 11:05 AM | #9 |
Old badass
Hmmm my truck 2.9 has a bypass actuator.
03-09-2022, 08:26 PM | #10 |
Drives: 2016 Camaro SS Join Date: Jul 2016
I am using it. It is quite nice for driveability and you can control the power with dial like pic. |
03-10-2022, 12:41 AM | #11 | |
06-07-2022, 10:23 PM | #12 |
Update: I got my Smoothboost installed but have hit a snag. It needs 4.0 VDC at WOT to fully close the bypass. I’m teed into the pedal sensor and was only getting 2.0 VDC at WOT, so I’m only getting a third of my full boost. Thinking my shop spliced into the wrong pedal wire, I grabbed a JMS voltage booster pedal harness since that had worked for me when I ran the voltage booster. Same exact situation, still only getting 2.0 VDC… anyone got any ideas???
06-08-2022, 01:32 AM | #13 | |
06-08-2022, 07:42 AM | #14 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
The JMS adapter wired into the 2V signal on mine. I thought it was 0-5v, but checking it I only got around 2 at wot. Maybe there’s another wire with a different signal? Wouldn’t think so but not sure.
(I don’t have smoothboost, I just checked the voltage at the JMS when I set it up)
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
