![]() Drives: 2012 Camaro 2ss 45th anniversary Join Date: Nov 2021
Code p0442 & p0445
I have a code for p0442 and p0445 I replaced my gas cap multiple times and it still will not go away. Does anyone know what else I should do it says there is a small leak and a large leak. Thanks
![]() ![]() Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
Without a scan tool it's really hard to diagnose this without throwing parts at it. The most common thing would be a leaking or stuck open evap vent valve.
^^^^ This. Good info. Also check all your evap lines as some of them are plastic and can crack or break and cause a leak.
| Tags |
| code, evap |
