Old 03-10-2022, 02:16 PM   #1
Tolstrup
Drives: Camaro 2SS/RS convertible 2011
Question Cutout for convertible
Mechanic claims that cutout isn't possible on Camaro 2SS Convertible from 2010, due to stiffeners under the car. Anyone got any experience to share with me - Any recomondations (brand, webshop etc.) much appreciated.
Tolstrup is offline   Reply With Quote
Old 03-10-2022, 03:08 PM   #2
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
You can place cutouts anywhere. I do not believe that there will be a place where they would not go to weld.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 03-11-2022, 08:11 AM   #3
BLU DUCE
BLU DUCE's Avatar
Should not be a problem. They get welded in the exhaust system,not in the dam frame.
Old 03-11-2022, 09:26 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You shouldn't have an issue. Find a different shop!! The get welded into the piping in front of the trans tunnel brace in the bend of the tubing, my buddy has a vert and has them. Here is a pic of where they go, not his car, just a reference pic for ya.
Old 03-11-2022, 09:45 PM   #5
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
0 mods are able to be done on 2010 convertible Camaros. Convertible Camaros didn't come out until 2011.
Check out my build thread
Old 03-12-2022, 09:59 AM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
lol, I didn't catch that one!!!
Old 03-12-2022, 11:35 AM   #7
Mike J
Mike J's Avatar
Drives: 2015 Topless Btch RS
Do some searching on this forum. There was someone who was making a special brace for the convertibles wanting cut outs, I think someone called it a “aph brace” to was to be bought, your garage was right, but it is possible with a type of brace for convertibles
Mike
Mike J is offline   Reply With Quote
Old 03-12-2022, 08:47 PM   #8
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
On my manual vert, the exhaust is the same as my 2010. I have the pipes from QTP to go with the low-profile cutouts. I'll be installing them and few other things soon. I see no reason it won't fit, at least on a manual.
Old 03-13-2022, 10:37 AM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
One of my friends here has a 2012 vert with the auto and has the NOWEEDS setup on his Camaro.
Old 03-15-2022, 03:31 PM   #10
Tolstrup
You are right - my typo
Old 03-15-2022, 03:32 PM   #11
Tolstrup
Mike
Thanks - I'll look for that
Old 03-15-2022, 03:35 PM   #12
Tolstrup
Thumbs up
Thanks everyone for the great input
Old 10-04-2022, 09:02 AM   #13
CamaroCracka
I finally got around to installing cutouts on my vert. I used the QTP low profile for 2.5" exhaust with their premade pipes. The one issue where I had to modify was that the larger crossmember with four bolts on each side would not go back on with the cutouts in place. I moved the crossmember toward the rear of the car lining up the front two bracket holes with the rear two chassis holes. Then I drilled an additional hole for the rear bracket bolt hole in the chassis and used a self-taping bolt and fat washer to lock it in nice and tight.
Old 10-04-2022, 02:07 PM   #14
George-CZ
George-CZ's Avatar
Are there any pictures from the installation?
convertible, cutout
