Old 03-12-2022, 04:38 PM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Shorty headers or manifolds with Huron twin kit?
I am switching to the Huron twin turbo kit. I installed the single kit last year. Do you guys see any gains on using a shorty header over the stock manifold? I have to look through my pile of junk for the manifolds or I found some shorties on Jegs for $250.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 03-12-2022, 09:02 PM   #2
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Top or mid mount? If mid mount, Huron has some great their-brand headers that breath well and handle the turbo weight (stout).
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 03-13-2022, 11:09 AM   #3
Omega
Drives: G8
The Huron manifolds look nice on the outside. The set I had were not flow friendly on the inside. This is the head flange, the primary to log junction was even smaller/not matched. You couldn't tell unless you stuck your finger down there.
Sent from my Pixel 4 XL using Tapatalk
Omega is offline   Reply With Quote
Old 03-13-2022, 12:10 PM   #4
IKILLEDSUPERMAN_ZL1
I can't find the stock manifolds. I can get some Pace Setter shortys for under $300.
Old 03-14-2022, 08:26 AM   #5
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
you need thick gauge stainless stuff... not sure paceheader fits the bill. check ebay for factory manifolds.
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 03-16-2022, 09:24 AM   #6
IKILLEDSUPERMAN_ZL1
I got some Doug Thorley shorties. They look pretty thick.
Old 03-16-2022, 09:36 AM   #7
RealQuick
Those appear to be the mild steel ceramic coated headers... not stainless unfortunately. The good news is they are 14ga tubes, so nice and thick. Not sure the flange thickness (probably 3/8").
Those should work for awhile.
Old 03-16-2022, 05:37 PM   #8
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
I have the ARH on mine on the car for a few years now. So far so good. The only issue is that you would need ceramic spark plug wires. Cylinder 4 and 6 will burn up regular spark plug wires pretty quick.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
