Old 03-14-2022, 11:41 AM   #1
Hcd3ss
Drives: 2011 camaro 2ss/RS
Rear upper shock mount question
I upgraded my upper shock mount in the rear of my 2011 SS. The new mounts have oblong mounting holes. So it seems that there is a discrepancy on the exact mounting location, since they can essentially twist a little before completely locking down the mounting bolts.. how should this be handled?
Hcd3ss is offline   Reply With Quote
Old 03-14-2022, 11:51 AM   #2
gtstorey
What did you upgrade to? Although I don't know that it matters for a shock mount. It isn't like the front that can change camber and caster.
Old 03-14-2022, 08:31 PM   #3
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Curious what mounts you went with as well, I Just got a Z/28 set. I am not aware of any adjustment or movement.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-31-2022, 01:41 PM   #4
JolantaAgata
Drives: Volvo
He said they have oblong holes
JolantaAgata is offline   Reply With Quote
Old 04-01-2022, 09:39 AM   #5
fz4k98
Drives: 2013 1ss
Are the oblong holes all in the same direction? and are there any holes that are not?
If some are in one direction and others are in a direction 90 degrees to the others it will still hold in place. If there is one small round hole and others are oblong it will also hold in place.
Can you post a pic?
fz4k98 is offline   Reply With Quote
Old 04-01-2022, 10:24 AM   #6
gtstorey
Hcd3ss hasn't posted since he started this thread.
Old 04-02-2022, 02:30 PM   #7
kevint
Drives: 2013 1SS
They help with getting the bolts up into the body. It's pretty tight up there.
kevint is offline   Reply With Quote
