Old 03-19-2022, 09:37 PM   #1
km9v
Drives: 2011 Camaro SS/RS M6
Strange AC problem
I noticed a strange AC problem today. The driver's side vents get slightly cool air & the passenger side get full cold air. I've tried adjusting heat, the floor, bi-level buttons, nothing corrects the issue. Anyone experience this issue? 2011 SS
km9v is offline   Reply With Quote
Old 03-20-2022, 12:39 AM   #2
PaulsSS
Drives: 15SS Camaro
Maybe the blend door has broken off and is causing this.
PaulsSS is offline   Reply With Quote
Old 03-20-2022, 01:40 AM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Could be just low on freon but, check this out, as well.
Heater Blend Door Database
0stones0 is offline   Reply With Quote
Old 03-20-2022, 01:58 AM   #4
InFiD3ViL
InFiD3ViL's Avatar
Oh yeah, we have seen it. Unfortunately it seems as though every 5th gen owner may get to experience this mark of GM excellence at some point in their ownership.
It usually points to a broken blend door (temperature door). Follow stones advice and read through the very handy database he created.
Old 03-20-2022, 09:41 AM   #5
badcompany
Drives: 2010 Summit White 2SS
Mine did this recently. I researched and researched, everyone said blend door but I wasnt ready to just jump in and do that right off the batt. My driver side was warmish and passenger side blew cold just like you stated yours is doing. Ended up being low on freon. Id highly suggest checking that first before you go off the deep end and just replace the blend door just because.
badcompany is offline   Reply With Quote
Old 03-22-2022, 02:47 PM   #6
km9v
I'll try that first. It's the cheap/easy place to start. If that's not it, I may look into the heater by-pass valve fix. Living near the gulf coast, AC is on 90% of the time.
Old 03-22-2022, 04:41 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Drive faster.... no AC needed.
Mods:
Old 03-22-2022, 04:58 PM   #8
gtstorey
Driving faster only helps a little when the humidity is approaching 100%.
Old 03-22-2022, 05:16 PM   #9
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Driving faster makes for more of the $6 gal gas stops - and it’s air conditioned in the Quik Mart! (and they sell beer)
Moto-Mojo is offline   Reply With Quote
Old 03-22-2022, 11:21 PM   #10
ssonic2013
ssonic2013's Avatar
Drives: 2013 Camaro ss
I'm not very mechanical,so glad I took out an extended warranty when I bought my 2013 SS. Will add though whoever designed the HVAC system on these cars should be reassigned to other duties.
ssonic2013 is offline   Reply With Quote
Old 03-25-2022, 08:28 PM   #11
barkeater46
Drives: 2010 Camaro 2LT/RS
Looked good in CAD.........engineers and designers should do a year in the field before they are turned loose
barkeater46 is offline   Reply With Quote
Old 03-25-2022, 09:12 PM   #12
Royal Tiger
Drives: 2013 2SS/RS Convertible
Remember as long as the car makes it to the end of the warranty period GM could care less if it blows up the next day.
Royal Tiger is offline   Reply With Quote
Old 04-21-2022, 01:15 PM   #13
km9v
It turned out to be low on refrigerant. I picked up an AC recharge kit for about $32. Works great now. I still don't see how being low on refrigerant would cause one side to be warmer than the other, but whatever, I'm happy it's fixed.
Old 04-21-2022, 01:50 PM   #14
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
That was a temporary fix, if you were low it is because there is an issue with the system. They need to be properly evacuated and filled under vacuum, and those recharge kits don't really do it properly.
I would recommend saving up some money, and then when this happens again (depending on the severity of the leak) getting it professionally diagnosed to find where the leak is and repair there.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
