Old 03-19-2022, 09:48 PM   #1
ICUP
Drives: Chevy Camaro
370 or 408 or 416
Hey all. Long time lurker 1st time posting. Looked through a bunch of threads, and it seems like it’s a mixed bag of info. Looking for recommendations on a couple of things.
Have a 15 1le with ecs 1500, and my engine took a dump. I think it was a bad tune from the get go. Heads are fried and Cylinder 3 is cracked, and bent a rod.
Anywho, I’m planning on get a new long block and I’m contemplating on a couple of things. Planning on doing e85 with the DSX kit, and just want to stay between 800-900whp.
1. Should I stick with stock cubes or go 408/416?
2. Which injectors ID1050 or ID1300?
3. Forged crank necessary at that power level?
4. Texas Speed/TMS or other for engine options?
5. What CR?
ICUP is offline   Reply With Quote
Old 03-19-2022, 10:51 PM   #2
gsxrturbo
Drives: 2010 ss
i asked my tuner the same question.he told me to stay stock cubes and spin the hell out of it.I have the same blower with cam and other modes on stock block,and im at 845rwhp at 6500.He also told me the stock crank will handle more then 1000whp.And he tunes a hell of alot of big hp cars.btw on on ID850's
gsxrturbo is offline   Reply With Quote
Old 03-20-2022, 09:41 AM   #3
ICUP
E85 for the ID850? What’s the duty cycle?
Old 03-20-2022, 03:36 PM   #4
gsxrturbo
Drives: 2010 ss
sorry typo 1050's these are in the mid 70's
Old 03-21-2022, 11:47 AM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
1. You can make that power on stock cubes. It's just easier with more cubes.
2. I'd suggest the 1300's. The 1050 will limit you once you figure out your HP ain't enough; the DSX system will keep up.
3. Stock crank.
4. TMS assembles good stuff. Lead time?
5. 10.5:1 to 11.5:1 works good with 93 or E85. With the higher CR, just have to be more careful with timing in boost. I don't think it will limit you for power at all - the tune is everything.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 03-21-2022, 04:02 PM   #6
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Nobody ever sticks to their desired hp goals
1. If you are dead set on that blower and power level, than stock cubes. If you think you may switch to a bigger blower down the road and shoot for ~1000rwhp then go 416ci. If you think you may want to push well past 1000rwhp, then go Iron 408ci
2. ID1300... or go bigger... like FIC1600 or ID1700
3. If sticking with stock cubes and ECS1500, cast crank is probably ok.
4. Texas Speed
5. 10-10.5
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
RealQuick is offline   Reply With Quote
Old 03-21-2022, 05:39 PM   #7
ICUP
3. Stock crank.
I guess I’m looking for more torque under the curve. No idea on lead time yet. There were variations on the long locks that I was looking at on TMS’ website, but they changed it up, and cost jumped up 500-1000$ on avg. They have 800hp 370 or 900hp with 408 (forged crank), and with ARP main stud it’s rated for 1100hp. I was thinking 10.5:1. I know with the higher CR I run the risk of detonation and the tuning window is smaller. However, with e85 it’s quite forgiving.
4. Texas Speed
5. 10-10.5
No one ever really does, but I think 800-900whp is a good street setup. I can’t get a hold of anyone from TSP. :(
Will I run out of blower with the 408/416?
Old 03-22-2022, 12:15 PM   #8
AGP Turbo
Drives: All things Turbocharged
If you want more torque under the curve then 416 no question. Use a smaller torquey cam and set everything up to only rev to 6500. Then max out the pulley ratios to get it to come in as fast as you can. For a dedicated E85 set-up go like 10.5:1. But if you are really only going to have a Novi1500 I'd just do a 9.5:1 pump gas car and not bother with E85.
Or reconsider your overall goal since you are going built motor anyway and start aiming for 1000+whp on a iron 408 short block.
AGP Turbo is offline   Reply With Quote
Old 03-22-2022, 03:28 PM   #9
ICUP
Definitely want to stick around 800-900whp. Anything more, then traction becomes an issue. Cam wise, I was thinking to go with their middle of the road 236/250. At the end of the day, I’m just looking for the best bang for the buck long block option.
Debating now if stock size lower pulley with my current 3.47 upper… ORDoing a 10% OD option…. OR stick with stock size and maybe drop it down to a 3.33.
