Old 03-26-2022, 05:56 PM   #1
Mike Cordero
Drives: 1971 Camaro Z-28
HELP PLEASE
Changed the battery today. Plug a battery pack to battery wires and didnt loose any configuration including radio but now have a read at gauges area that read to rise and lower the driver side window. It lacks those centimeters that opens and close the window by itself. I can close it fully manually but doesnt happens spontaneously as must happens. What i can do?
Mike Cordero is offline   Reply With Quote
Old 03-27-2022, 10:21 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
When you push the button to lower the driver side window, when it gets to the bottom, hold the button down for about 2-3 seconds after the window stops at the bottom, then pull the button, and hold it to roll it back up to the top until it is fully closed, then do the passenger side the exact same way, and then you should be good. Took me a couple tries to figure that out. lol. Good luck, hope this helps..
Old 03-27-2022, 11:06 AM   #3
Mike Cordero
Thanks for the info. Fixed.
Old 03-27-2022, 11:15 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Awesome! Glad you got it resolved..
