Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 04-05-2022, 10:13 PM   #1
Kman13RSSS
Drives: 2013 IOM 2SS/RS 2.9 Whipple
Rotary SPOA10
Hi, I’m in need of some dimensions that I just can’t seem to find. I am looking for the outside of post to outside of post dimension. I have overall, drive through,etc but need that 1 to figure out placement of carrier beams in the ceiling. I’m hoping to have the lift post come next to the beam as opposed to under to save on ceiling height. Sooner I can figure this out the sooner I can order steel beams. Thanks
Kman13RSSS is offline   Reply With Quote
Old 04-06-2022, 10:26 AM   #2
1911 1LE
Drives: 2015 SW 2SS 1LE
I just measured mine at eye level. 128 1/4" I would make it a little wider span, just in case. BTW, mine is 138" over all at the base plates. Hope this helps
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is offline   Reply With Quote
Old 04-06-2022, 01:58 PM   #3
Kman13RSSS
Thank you. That helps a ton. I’ll have to double check but I believe that gives me plenty of room to set it inside the beam instead of under. How do you like the lift?
Old 04-06-2022, 04:43 PM   #4
1911 1LE
Love it! So do all my friends and family. I didn't hard wire mine. I used a RV extension cord and plug it into my 220v welder plug close by.
Old 04-06-2022, 08:19 PM   #5
Kman13RSSS
That’s good to hear. I miss having a garage with a lift. Hopefully lumber prices start dropping so I can start framing. It looks like you’ve got good tastes, Camaros and guns. I love the 1911’s. Best looking gun out there. I guess my collection of a dozen or so speaks to that.
