Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 04-06-2022, 06:58 PM   #1
mactube
Drives: 2015 Camaro Convertible
Looking for discontinued ZL1 Rims
One of my rims ( maybe 2 ) seam to be bent because the steering wheel starts shaking at 70 mph since I already bought new tires, I might have to replace 1 or even both rims in the front.
The problem is, I can't find these 22" rims :
https://drive.google.com/file/d/1tCQ...ew?usp=sharing
Does somebody have an idea where to find them I think they are called ZL1 Replica.
2x 2015 Convertible 1LT
- White on Black 22”s
- Silver Stock
mactube is offline   Reply With Quote
Old 04-07-2022, 07:43 AM   #2
FASTFATBOY
Drives: 2013 ZL1
If you replaced tires the tire store "should" have let you know you had bent wheels as it is very easy to see on the balance machine.
I would take it back to the tire store and tell them it has a vibration and check for bent wheels.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 04-07-2022, 09:08 AM   #3
bsn
Drives: 2013 ZL1
They should be able to be straitened by a wheel shop if not to badly bent. Do you recall an incident when this happened? If it started after your new tires its likely improper balancing, a tire defect, improper/over torque of nuts or dirt/debris between the wheel and hub.
bsn is offline   Reply With Quote
Old 05-24-2022, 03:57 PM   #4
mactube
All the Tire Places where just speculating ... and of cause sell new tires...
" it's probably the tires .. buy a set of new tires an your problem will be solves .. "
- Silver Stock
