Old 04-08-2022, 11:48 PM   #1
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Intake manifold questions
Hey guys I was wondering if it would be worth it to go with say a fast intake and 102 throttle body to get a few more hp and higher up in the rpm range? I currently have a stock intake with the SS1 vvt and it produced 438 rwhp at 6100 rpm but carried it to 6400 rpm. What are your thoughts on this?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 04-09-2022, 02:36 AM   #2
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 04-09-2022, 02:54 AM   #3
morepowerjoe
I don't really know if that answers any questions for me since there using a SS4 cam. My question is if it will do anything for my combination getting me up there in the 6700 rpm range with my SS1 vvt cam.
Old 04-09-2022, 06:41 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
It's not worth it IMO. With the FAST you will lose more low/mid range than you will gain on the top end. Plus, the gains that GPI shows with the SS4 is after your cam peaks currently.
Money would be better spent (and saving some $$ for other things) for a rod mod & ported intake. Are you on stock converter?
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 04-09-2022, 06:46 AM   #5
morepowerjoe
Yeah I'm still running the stock converter.
Old 04-09-2022, 08:34 AM   #6
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Rod mod intake from gpi would be the best bang for the buck. You send them the old one and it would cost you 1/3 the price of those other manifolds.
Only other one worth dropping money on is the lod with a 102 opening. But that combo cost a lot more for such a little gain over rod mod. Ported throttle body is also a cheap upgrade that I think is worth it. It increased my throttle response nicely.
But converters are a huge upgrade on our cars.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 04-09-2022, 08:45 AM   #7
Ashen 6.2
Ashen 6.2's Avatar
Converter would be a great upgrade and compliment your cam really well. My buddy had the SS1 with ported heads and then added a 258 single disc 3700 converter and it was like a whole new combo after that.
Old 04-09-2022, 08:47 AM   #8
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
Back in my early days of modding when I had the ss1 cam and did the rod mod I felt the difference. I re-ignighted my MOD SICKNESS and made me start doing other stuff in search of that feeling.
LETS GO!!!
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 04-09-2022, 08:47 AM   #9
morepowerjoe
I'm gonna think about the gpi rod mod. I know a converter is a big deal but I think I'm going to wait until my rebuild before I do that because I'm at 166k right now. lol
Old 04-09-2022, 09:04 AM   #10
Ashen 6.2
Ashen 6.2's Avatar
gotcha. Yeah, if you planning a rebuild would be better to get a converter to match the specs of that build.
Old 04-10-2022, 11:02 AM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Great advice here. The stock manifold with the rod mod done to it from GPI will be the way you want to go since you are staying under 7k rpm and the small cam. And as mentioned, a ported TB will help increase your throttle response a lot, as it did when mine it was the stock manifold. When you do your rebuild and want to take it to the moon in rpm, the LOD can't be beat!! Good luck.
Old 04-11-2022, 09:06 PM   #12
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Not worth it really, unless you wanna burn some cash. Get that stock unit modded.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 04-11-2022, 09:26 PM   #13
morepowerjoe
Thanks guys I think I will hold off until my rebuild and decide what cam I'm going to go with cause then I'll know what rpm range I'll be in. Thanks again.
Old 04-12-2022, 09:22 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes sir. So many ways you can go depending on what YOU are going to be using the car for. The stock manifold/heads just can't be beat as it is good up to and a bit beyond the 6800 rpm you want to take it to. Mine before the LOD we made 460 rwhp at 6800.
