Old 04-09-2022, 05:58 PM   #1
Spidey323
Drives: Chevrolet Camaro 2014
LFX Catless Low-end RPM crap
Hey guys,
I have question how to improve low-end torque with catless setup. I got ARH catless downpipes... its sounds good, got little HP at high-end but at low rpms it noticeable diffrence to minus torque ;/ is x-pipe would help with that? Or need to back to cats and be happy again? Or weld something more to get right OEM torque from bottom? Please help
Spidey323 is offline   Reply With Quote
Old 04-10-2022, 09:37 AM   #2
PaulsSS
Drives: 15SS Camaro
Did you remove the factory H pipe section?
PaulsSS is offline   Reply With Quote
Old 04-10-2022, 07:10 PM   #3
Spidey323
Nope, all is stock. Only remove the cats
Old 04-10-2022, 07:24 PM   #4
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
I wouldn't have though that it would have made that big of a difference (I thought the pipes would have had the opposite effect and increased torque) but you possibly lost torque due to a drop in cylinder pressures from the increased exhaust flow. Retuning the car might fix the issue.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 04-11-2022, 06:43 AM   #5
Spidey323
Ok i will check this, but have another question... Is it safe to get on V6 2.5 pipes all the way? or better stick to stock and do 2.5"->2.25" ??
Old 04-11-2022, 07:04 AM   #6
KillboyPowerhead
Drives: 2015 Z/22
Safe to go 2.5" all the way. Not sure if you'd lose any power in doing so, but if you did a doubt you'd even notice - I had 2.5" for a bit and didn't notice any difference.
KillboyPowerhead is offline   Reply With Quote
