![]() Drives: 2010 chevy camaro ss Join Date: Jan 2021
Solid roller setup for sale.
I have a solid roller setup for sale. Morel 5425 ultra pro hippo lifters, btr shaft rockers for rec port, ultimate rpm springs, smallwood race development custom grind cam and comp xda pushrods. Valve lash is set via shims in the pushrods. Cam specs are 236/244 667, 639 114.5. Made excellent power.
I'm doing another build and am going bigger on everything. 1100 miles on the combo. The cam has a choppy idle and pulled to 7600 with no issues. Cam was speced for 6766 twins, fast high ram and 376 cid. $1200.00 |
Sorry, lift is 667, 638. My bad
![]() Drives: 2011 Camaro SS Join Date: Jul 2017
Badass stuff! GLWS
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
What is included for 1200$?
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
