04-19-2022, 01:25 AM | #1 |
Drives: 2011 SS mara Join Date: Apr 2022
Is this a proper alignment?
2011 SS FE3 Camaro
I went to the dealer and asked for street performance spec alignment. I got the car back with this readout and they told me that this is the best alignment I will get with stock parts. Is this a proper alignment for street performance specs? I know that they have done alignments for me in the past which felt amazing, but this time it was different. Instead of taking the normal 3 hours, they finished in half the time. Do you think they did a good job? (noting the front tires have uneven wear before the alignment) |
04-19-2022, 06:27 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Any suspension mods? Lowered?
Rear camber is way off side-to-side and no reason they can't be the same assuming the car hasn't been hit. I'm lowered about 1.5" in the rear and my guys could still get -0.5°; if you're not lowered you should be able to get -0.5 no problem. Adjusted via the lower control arm bolt at the subframe. Caster isn't adjustable from the factory and you'd need caster plates or to modify the radius rod bolt hole at the subframe to move the arm inward (closer to the centre of the car) to get more castor. I think you'd want a bit more toe for an "aggressive" alignment, maybe 1/16" front, 1/16 to 1/8" rear. Not sure what that translates to in degrees. Overall looks like they either didn't know how to properly align the car or were just too lazy to get you even side to side. My guys spent about two or two.5 hours and everything was dead nuts even side-to-side.
04-19-2022, 08:17 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I always take in a copy of JPSS alignment sheet when I get an alignment and get the "Aggressive Street" settings. Seem to work well.
https://www.camaro5.com/forums/showp...52&postcount=2 There are typos in the OEM columns so don't use them. |
04-19-2022, 03:21 PM | #4 | |
Thank you and everyone for contributing. The dealer agreed to fix it |
Tags |
alignment, camaro |
