![]() Drives: 2015 Z28 Join Date: Feb 2022
Is my PTM working right?
Been playing with PTM settings on my 2014 Z28 but concerning that if I change the PTM mode the Traction Control and Stability Control lights come up, suggesting they are both OFF.
As an example: Get in car, start up, no warning lights on dash. Press the 3rd button 3 times and I get the PTM menu appear, but also the TC and Stability OFF lights come illuminate on the dashboard. I can toggle through the PTM levels and select whatever I like but the TC/SC lights stay on, the only way I can make TC/SC lights go off is by pressing button 3 again but this returns the car to PTM 2. If Im selecting different PTM modes are the TC and SC actually still on despite what the dash is telling me? Or is this a fault, should I be able to select different PTM modes without the TC/SC lights coming on? Car is 150hp more than standard so would be good to know where I stand with TC particularly, thinking its on when its actually off could be "entertaining" .......
![]() Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Yes the lights will be on. It is best explained in the manual, as it goes over all the modes
Some reading material
Top job, thanks guys - I didnt get a manual so have been figuring out as I went along .......
Hopefully this link works. I have this saved to my computer as well
https://cdn.dealereprocess.org/cdn/s...015-camaro.pdf |
#6 |
![]() Drives: Z/28 Join Date: Feb 2022
It's not very intuitive and I had the same thought. Had to review the manual to understand this function.
#7 |
![]() Drives: '15 Z/28 #698(A/C,AW) & other stuff Join Date: Oct 2017
Don't forget the "all off" mode. Hold down 2 buttons for about 7 seconds to turn all nannies off.
Been a while, but I believe 2 buttons on right..?? |
#8 | |
I might be a bit old school but when a car tells me something is turned off, I tend to believe the car ![]() Not a mistake you want to make on a wet morning with 570rwhp
