Old 04-19-2022, 10:44 PM   #1
ryan_g.57
ryan_g.57's Avatar
Drives: 2014 2SS
"Shift Denied" From 5-6
Hey guys,
New here. I recently bought a 2014 SS with the A6 transmission. After romping around for a while I noticed my trans temp gets close to 210. I'm not sure if this is causing the issue but when I try to tapshift from 5th to 6th in manual mode, it says "shift denied". and it's not because i'm at too low of RPMs, I've tested it at different speeds. Even if I put it back into S mode or D, it will stay in 5th gear, even going 80+mph.
This has happened once before and it was only after I was getting on it for a while and my trans temp went up around 210. I drove to where I was headed. Parked. Got back in it a few hours later and didn't encounter the issue again until just now.
Has anyone else experienced this? Should I be worried?
Thanks in advance.
ryan_g.57 is offline   Reply With Quote
Old 04-20-2022, 10:48 AM   #2
ryan_g.57
ryan_g.57's Avatar
Drives: 2014 2SS
*Correction: I think the temp is closer to 250.. I was looking at the gauge and its on the tick mark between 180 and 320
Old 04-20-2022, 10:59 AM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
First thing I would do is drop the pan and change fluid and filter, but you might need to get the trans checked by a shop if the car itself isn't shifting.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 04-20-2022, 11:12 AM   #4
ryan_g.57
ryan_g.57's Avatar
Drives: 2014 2SS
Okay, it's strange because it's only happened twice and goes away as soon as it's parked for a little while. Driving to work this morning, it was perfectly fine.
Old 04-20-2022, 08:54 PM   #5
ryan_g.57
ryan_g.57's Avatar
Drives: 2014 2SS
Also looking into transmission coolers, if anyone has suggestions. The AMD seemed popular but it looks like they don't sell them anymore.
Old 04-21-2022, 06:41 AM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
When I leave work and get on the HWY/Freeway my car takes a mile or so before it will make the 5-6 shift.
I think the tcm needs to see a certain temp first.
The opposite is probably true as well with high temps and your from AZ.
I would mount a quality after market trans cooler to help with those extreme temps.
Then get a trans flush and fill with some nice new Dex 6
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 04-21-2022, 07:50 AM   #7
gtstorey
Tru-Cool, either LPD4921 or LPD4739
http://media.spicerparts.com/cfs/fil...store=original
Old 04-21-2022, 09:30 AM   #8
ryan_g.57
ryan_g.57's Avatar
Drives: 2014 2SS
Thanks for the help! Any opinions on the Hayden?
Old 04-27-2022, 08:11 PM   #9
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
The TCM has different shift points in Sport and Regular mode also if cruise control is used or not. It also has different shift points at a certain tranny temp. You might reached that temperature limit settings which is denying that shift in question. I don't have my laptop in front of me, but I can check when I have a second.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 04-27-2022, 10:36 PM   #10
SaReNi
Drives: 2012 SS
whats the difference. how difficult is the install. thanks
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 04-28-2022, 07:56 AM   #11
gtstorey
Difference is size/cooling capacity and connection types.
These are not custom for the camaro bolt-ons. You will have to come up with your own mounting and hoses/connections.
This is what I sort of followed for my install. I did cut the barbed ends off and convert it to an lines with a 3/8 to an compression style fitting.
https://www.camaro5.com/forums/showp...0&postcount=65
Larger cooler install
https://www.camaro5.com/forums/showt...light=tru-cool
2ss, automatic, shift denied
