Old 04-19-2022, 11:24 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Speed Engineering
Are speed engineering headers any good? I was thinking about them for a cheap but will get the job done pair of headers.
jesse121pm is offline   Reply With Quote
Old 04-20-2022, 02:15 AM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
They are a great budget header and have been making LS parts for a long time.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 04-20-2022, 08:33 AM   #3
gtstorey
They have worked well for me. I think fitment issues may be a little more common than more expensive brands, but mine had no issues.
Old 04-20-2022, 10:35 AM   #4
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
Great budget headers. The provided header bolts and exhaust clamps suck, but reuse the factory bolts or get ARP bolts and grab a better pair of claps at the parts store, you will be set.
I run them and had them ceramic coated at a local shop. Mine required a little massaging on the passenger side, other then that, they have been great for about 8k miles.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 04-20-2022, 02:23 PM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
No problems with mine.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 04-20-2022, 02:57 PM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I have a set on my truck and I have a set of Stainless Works on my vert. You can see the quality difference, but they work fine. No issues at all. I did not use the bolts that came with them either. IIRC, they were black oxide finish or at least black and rusty header bolts suck, so I used stainless.
Old 04-20-2022, 07:41 PM   #7
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
I take a lot of pics so I can show you what fresh out the box looks like and how they are 3 1/2 years later. I bought the o2 sensor harness extensions as well.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 04-20-2022, 09:27 PM   #8
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
If cheap, get the job done header is what you're after, then you're right on point. You'll likely have to massage them to fit, but they're cheap and will get the job done.
Check out my build thread
Old 04-20-2022, 10:18 PM   #9
Royal Tiger
Drives: 2013 2SS/RS Convertible
I’m a huge you get what you pay for proponent, as well as a buy American guy. I went with American Racing long tubes and high flow cats, but Jannetty replaced my cats with Kooks green cats to handle the boost. He also ceramic coated my headers.
Royal Tiger is offline   Reply With Quote
Old 04-22-2022, 02:09 PM   #10
13_SS_RS
Drives: White 2013 SS/RS l99
They probably are made in china which sucks but they are good quality. I have their headers and 3" exhaust. All of it went on fine and I had no fitment issues. I've also heard people complain about the clamps but they worked fine for me. Not knocking anybody, but "you get what you pay for" isn't always true.
Current: 2013 summit white Camaro 2SS l99
CAI, long tubes, ported tb, tune
Previous: 2008 jet stream blue Corvette Z06
Airraid, Corsa, MGW shifter SOLD
13_SS_RS is offline   Reply With Quote
Old 04-22-2022, 04:20 PM   #11
Royal Tiger
I find it more true than not from everything from car parts to electronics to firearms. Sure cheap stuff works, but again it costs more for a reason. Better materials, better fit & finish, etc…. Looking at speed engineering than AR or Kooks you can see why one costs more.
Old 04-23-2022, 01:01 AM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
https://youtu.be/wS94DzQ1NuM
Going strong for over 2 years on my ZL1. Shameless self promoting video above.
FasNuf is offline   Reply With Quote
Old 05-25-2022, 01:18 PM   #13
TooleyOnDeck
Tooley
TooleyOnDeck's Avatar
Drives: '18 2SS 1LE
I just installed SE headers last night and the passenger side is touching my subframe, going to mark the area, take them off, and dimple them to clear it... but for $400 vs $1500+ I can't be upset about the extra work.
TooleyOnDeck is offline   Reply With Quote
Old 05-25-2022, 02:00 PM   #14
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
I prefer SLP....only ones who work with and for General Motors, so the quality is right, and the fitment is right. As for the factory bolts....throw them in the trash! If you use them long enough you will understand why. ARP is number 1 in fasteners so I use them. Agree with Royal Tiger....almost always you get what you pay for!
NOT A 45 is offline   Reply With Quote
headers
