![]() Drives: Super Spec Miata LFX Track car Join Date: Apr 2022
Anyone run this TB on their LFX?
GM 12617792 off the5.3 liter vehicles. I just got a junkyard 2015 Camaro RS LFX with only 36k miles. Intake is modified with filled chin, ported to match this TB and phenolic spacer. 3.5 inch pipe.
Anyone else use this TB? Last edited by drgoodwrench; 04-27-2022 at 02:06 PM. Reason: Picture |
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
Interesting. What's the diameter?
It is 80mm .
