Old 04-27-2022, 02:39 PM   #1
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
New coilover ride height.
What do you guys think about this ride height? It's pretty much stock ride height. It's a drag oriented suspension and wheel set up. Should i drop it another half inch? Crap 1st pic is rotated wrong. Sorry.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 04-27-2022, 04:53 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Looks almost stock to me. I think it should be a tad lower, like 1 inch??
Old 04-27-2022, 05:52 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
Going for looks or function? JusticePete suggested not going lower than 26" in the rear (measured from bottom of wheel lip/rim to fender) for the sake of the axles/joints. I lowered mine such that the top of the tire was nearly flush with the bottom of the fender (about 25 5/8"), but I'm going to raise it in the near future to 26" for practical reasons.
KillboyPowerhead is offline   Reply With Quote
Old 04-27-2022, 07:18 PM   #4
IKILLEDSUPERMAN_ZL1
I want it to look better but can still hook. It just looks like a 4x4 to me. I'm going to measure it like you mentioned and see where it sits.
Old 04-27-2022, 08:39 PM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Drop it
joshnmn is offline   Reply With Quote
Old 04-27-2022, 11:22 PM   #6
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
What tires are you running up front & wheel width. The rear looks good but the fronts look a little skinny stretched on a wide wheel in the 1st pic.
acutron42 is offline   Reply With Quote
Old 04-28-2022, 02:35 AM   #7
IKILLEDSUPERMAN_ZL1
28×4.5×18 M&H on a 18x5 rim. The recommended rim width was 4 1/2 but I don't think the front rims come in a 4.5 width?
Old 04-28-2022, 06:03 AM   #8
acutron42
acutron42's Avatar
That is a common setup. I think it looks good, maybe a tad lower as already posted.
Old 04-29-2022, 11:31 AM   #9
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Drop it down more
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 05-03-2022, 07:21 AM   #10
Car Nation Videos
YouTube-Car Nation Videos
Car Nation Videos's Avatar
Drives: 2010 Chevrolet Camaro
Drop it lower
Car Nation Videos is offline   Reply With Quote
