Old 04-27-2022, 08:47 PM   #1
72 Z27
Drives: '70 Z28/RS & '14 Z28
OEM Wickerbill Washers
For those of you that have installed the GM wickerbill on their spoilers, how many foam/rubber washers does the installation take? 7 or 14?
Do the washers go between the bolt and wickerbill, wickerbill and spoiler, or both? I looked up the GM installation instructions and its vague, nor does it state the quantity that came with the wickerbill.
Thanks for any help.
Jeff
72 Z27 is offline   Reply With Quote
Old 04-27-2022, 10:12 PM   #2
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
1 rubber washer between spoiler and wickerbill. 1 rubber washer between wickerbill and metal washer. So 2 rubber washers per mounting hole, 14 total. If that makes sense.
If I’m incorrect then someone will chime in.
That’s how I understand it. But if your going to autoX or track it, I’d highly suggest to put a solid rubber strip that fills gap between spoiler and wickerbill to prevent dust,debris, rocks to get in between that space.
Good luck
SIM GhostrdrZ is offline   Reply With Quote
Old 04-28-2022, 08:45 AM   #3
Coz3z3
Drives: 2015 Z/28, 2015 1LE
I did what SIM did. And I believe my wicker came with like 20 of those foam washers. So yeah, I put two in each. I still have a couple extra lying around if need to replace some
Coz3z3 is offline   Reply With Quote
Old 04-30-2022, 10:17 AM   #4
72 Z27
Thanks for both of the replies. Exactly the info I was looking for.
Jeff
