ZL1 Garage Sale
OEM & Aftermarket ZL1 Parts for your consideration.
I have over 30 parts for sale, some are here not because they're so great, but because someone may want them even with the mileage and condition they're in. So come all budget builders and take a look. Pics will be available to persons that PM me with interest. I may try to upload the pics, but that would literally overwhelm this thread. Dayco 10% overdrive lower damper. about 10K miles Tick Performance Clutch Slave Cylinder Shims ( set of 3 sizes ) OE Leather Boot (no ring) OE LSA oil pump with 20K miles. (30psi hot idle at removal) K080670HD K080675HD K080653HD OE Lower Grill (minor scuff at tip) OE SC upper idler with good bearing.OE RH inner fender liner OE Trailing Arms (sold as set) OE Toe Rods (sold as set) Metco Valve Cover Breather MBR0003 Aftermarket Crashbar. Has towhook hole but tow hook wont fit ZL1 Rotofab HX reservoir plastic cap leaks OE HX with plastic trim and brackets OE SC idler bracket OE RH Headlight Assy (Factory HID damaged housing) OE Spare tire styrofoam OE LH A-Pillar trim GM Performance Timing Chain 10K miles OE Cam Gear and Bolt (single bolt style) DEI Header Wrap (less than full roll) SOLD - OE Leather Steering Wheel (manual trans) SOLD - OE Leather Shift Knob SOLD - OE Front & Rear Springs SOLD - OE LH Air Duct for Brake SOLD - OE Air Cleaner Housing & Ducting 11K miles. SOLD - OE Windshield Wash Bottle (no pump) SOLD - Spare tire pump kit SOLD - Elite Engineering Catch Can (3 port style) SOLD - OE 2014 taillights (sold as a set only) SOLD - OE Throttle Body SOLD - Skip Shift Eliminator Thanks , Mark
Thank You
I guess shipping the inner fender liner is possible but extremely expensive due to it's size. It's so expensive, I will probably scrap the piece to the recycling bin unless there is a local sale. It doesn't fold up like the cheap amazon crap so I don't think that's really an option.
Sorry guys. Mark
Thanks again!
Thanks guys
#6 |
Why the sale?
#7 |
#8 |
So they’re just extra, you still have the car?
#9 |
Yes, they're from FasNuf as I did the mods. The car is featured in my YouTube channel in my signature.
Thanks
#10 |
Many items still available
#11 |
Thanks guys for all the interest.
There's also a new video up on the channel today.
#12 |
Bump for your pleasure.
#13 |
bump.
Many things still available
#14 |
Added Skip Shift Eliminator
$10 shipped to you
