05-02-2022, 02:21 AM | #1 |
Drives: 2018 Chevrolet Camaro 2ss Join Date: Apr 2022
Launch Control Confusion...
Hello everyone! Recently purchased a 2018 2ss 8-speed automatic and wanted to test out the launch control. I did everything required (sport/track, stabilitrak comp mode, held brake, etc.), however, I can't find the display menu that says, "Press and Hold Brake". I cannot find it in the performance or options menu. Not sure what to do. I feel like I should have at least the launch option considering I've seen older models with it. Tried it once before researching correct requirements and didn't do it right. Tried it again knowing requirements and resulted in wheelspin and did not hold at 2k rpm.
Has anyone experienced this and if so, were you able to find an answer as to where it is or if it's included? Also, is the menu required to perform the launch? If not, when performing it, I mash the brake down, but do I rapidly hit the gas to the floor right after brake? I'm talking like a panic brake but with the gas. And correct me if I'm wrong, but even when hitting the gas all the way down, rpm should be holding at 2k right? Owner's manual and videos were not clear. Thanks. Here is a picture of the display I am mentioning on a different camaro: https://i.ytimg.com/vi/TWYBRp1FSl0/maxresdefault.jpg |
05-02-2022, 02:55 AM | #2 |
Drives: C8 Corvette Join Date: Mar 2013
I think the 16-18 model does not show this message. Just fully push the accelerator and the car should hold the RPM instead of letting it go to full. But to my experience the launch control is pretty much useless. Way too high RPM, resulting in too much wheelspin, and then letting the full rpm through too fast to often produce a burnout instead of a launch. It would recommend trying to find your own point around 2,5k - 3,5k RPM when standing and then gradually push the pedal more directly after launch to get a smooth transition to full throttle that actually gets delivered to the ground.
Best number I could get by myself in my manual 2018 SS was a 4.3s to 100kph (should be around 4.2s to 60mph).
05-02-2022, 05:32 AM | #3 |
Drives: 2022 camaro 2ss 1LE Join Date: Dec 2021
I know with it displayed, you have to press the brake almost all the way to the floor, pretty hard. Default on mine is set at 2k rpm, and can be adjusted up to 2.5k rpm.
05-02-2022, 05:49 AM | #4 |
I think Pre-Facelifts can't adjust the Launch Control RPM
05-02-2022, 05:51 AM | #5 |
It does not show up for this year. 2016-2018. Double tap the Traction control button and if it says Competetive Shift Mode you are good.
05-02-2022, 06:44 AM | #6 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
You definitely have to push brake ALL the way to the floor first. Then the gas all the way to the floor. The tires might chirp once while doing that before the ecu cuts power... then just let off the brake. Honestly though the launch control is (or was) pretty crap on my 17... i never use(d) it. Esp not now with the mods.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
05-02-2022, 08:34 AM | #7 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
2018 SS has no display or adjustable settings, just put in comp mode, make sure wheel is straight, stand on brake pedal like a panic stop, floor it, wait for RPMs to come up then release brake
Took me a couple times to get it right, key is to be very hard on the brake pedal
05-02-2022, 08:45 AM | #8 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
You have to stomp on the brake to the floor. Then floor the gas pedal. Watch the RPM's if they don't stop at 2k which is default RPM setting, then you didn't do it right. The older pre-facelift SS's did have a brake control display on the dash. I remember doing this on my older 2016 SS But I do not see this on my newer 2020 SS. I've elected to not use Launch control and just brake torque launch instead. I just don't trust launch control personally. P.S. when I say "Brake to the floor" I mean just that, if its not to the floor launch control doesn't work. Either way here's a video:
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
05-02-2022, 10:37 AM | #9 |
Drives: 21 ZL1 Join Date: Feb 2022
Funny thing, the launch control almost NEVER worked in my 2018 ZL1. But in my 21 ZL1 it works flawlessly. Both cars are a10s. And I was always doing it by the book. Glad its better in the newer cars. But nothing replaces off idle stab.
05-02-2022, 01:35 PM | #10 |
Thank you everyone for your input. This clears up my confusion about the display page, now I just got to see if I can get it to launch. If not, I will try to hold it at 2.5-3.5k rpm as suggested. Much appreciated!
05-02-2022, 01:36 PM | #11 | |
05-02-2022, 01:38 PM | #12 | |
05-02-2022, 01:39 PM | #13 | |
05-02-2022, 01:42 PM | #14 | |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2010
If your seatbelt isn’t on it wont work either… friend found that out…
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled 2004 Silverado single cab 4.8l v-8 2wd -- Traded 2018 Camaro SS 1LE -- Current DD |
