Old 05-02-2022, 09:07 AM   #1
L7EWB
L7EWB's Avatar
Drives: 2014 2LT RS
High pressure fuel pump leak
I have a 2014 3.6 and it seems to be leaking from the high pressure fuel pump around the electrical plug area, is this an easy swap, can it be done from under the vehicle? Thanks
L7EWB is offline   Reply With Quote
Old 05-05-2022, 10:13 PM   #2
Pearlj10
Drives: 2011 Camaro 2LT
Ugh. I was interested in upgrading my HPFP after going supercharged since that is the weak link in the fueling system. In that process, I looked at write ups on the pump replacement. It didn’t look fun. Doable with a good box of tools, but not fun. Check out this post and the note on tools in post #9. This should be basically the process you’re up against.
https://www.cadillacforums.com/threa...ement.1088243/
Pearlj10 is offline   Reply With Quote
