Old 05-04-2022, 05:31 PM   #1
Nate2SS
Nate2SS's Avatar
Drives: 2011 Camaro SS LS3
Thumbs down AEM wideband sweeping
Hey all, I recently got my wideband working in my car and had a few questions regarding the numbers I'm seeing.
On idle I see anywhere from 13-16. I understand this sweeping is normal as the computer is constantly making adjustments for stoich ratio.
On WOT I see anywhere from 11-13 sweeping which I understood is not normal as the car should be pulling from the tune to have the right ratio. Someone please explain if this is incorrect.
I lugged the car in 5th gear in an effort to see PE and am getting 11.5 consistently. This is the only time I ever see a super consistent range.
I understand sweeping is okay on light throttle and idle but how far should it sweep?
I will be calling AEM in the morning to get a better idea of what they think it is but wanted to see if anyone else had similar experiences?
2011 2SS/RS 6M: Hurst Short Throw Equipment, Speed Engineering Headers, Spectre CAI, BTR Stage 3 Camshaft 229/244 .630"/.615" 113+4, Chromoly Pushrods, .660" Springs with steel retainers.
Nate2SS is offline   Reply With Quote
Old 05-04-2022, 11:44 PM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
That's a large swing. Is the AEM able to be switched to lambda instead of afr? I have an AEM 03-0300 in my STI and switched to read lambda. It is rock solid at 1.00 at idle. The Autometer in my Camaro bounces from .95 to 1.02 at idle. Having a wideband that displays afr is tricky. Because the stochiometric value can vary due to the gas. Gas with 10% ethanol is 14.1. Straight gas is 14.7. Your wideband will either have a fixed value or a programmable value. That value needs to match the gas stochiometric value. If not, you'll need to add or subtract an amount to get the correct afr. My guess, the AEM is reading correctly and the cam/tune is responsible for the swing. NA cars should be about 12.5 afr, forced induction 11.5. Provided you made the corrections for gas and programmed stochiometric values. Lambda is just lambda. At idle it should be about 1. Wot NA .85 and FI .78. If you wanted to convert to afr, multiply the lambda value by the fuels stochiometric value.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 05-05-2022, 05:23 AM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
That is a bit strange and a rather large sweep. At WOT I see a sweep from 12.3-13.0 on my new tune. Old tune it would hold a consistent 12.2-12.7.
Is it mounted at the correct position? how old is the sensor?
Old 05-05-2022, 06:31 AM   #4
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Mine sweeps too but not that extreme at WOT. My guess is the fuel tables in the tune need tweeking.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-05-2022, 07:49 AM   #5
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Interestingly, mine was always sweeping like you mention with my old engine. It was also mounted post-cat which is not ideal. With the new engine I added a bung in the collector so it’s now next to the leading O2 sensor - it’s reading a dead-steady 14.7 and doesn’t sweep. No tuning has been changed from the previous build (still trying to break in before new tune).
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 05-05-2022, 08:04 AM   #6
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
Mine has a huge sweep. At WOT I see anywhere from .88 Lambda to 1.04 Lambda. I mounted the bung in the offroad connector which have the same shape as a cat. So, this could be a mixture of two problems. 1. Mine tune is still not right, but it has been getting email tuned since January and will hopefully be right soon. 2. Since the bung is mounted in the larger diameter section of the offroad pipe it might be causing some reading issues.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 05-05-2022, 10:01 AM   #7
Nate2SS
Nate2SS's Avatar
Thanks all, the sensor is less than 24 hours old. I just got it replaced through AEM. The car is a cam only too. I’ll mount the gauge and record some of what it’s doing and post here for others to give more advice.
Old 05-05-2022, 02:36 PM   #8
Nate2SS
Nate2SS's Avatar
Here’s some videos that you guys can check out and see what it’s doing. My next option is to check again for exhaust leaks and vacuum leaks.
https://youtube.com/shorts/oG4pVodYPlk?feature=share
https://youtube.com/shorts/8dHino_hHbU?feature=share
https://youtube.com/shorts/q1MNOHMHPEs?feature=share
Old 05-05-2022, 03:05 PM   #9
TheFlyingBananaSS
It's normal for it to go lean after you take your foot out of it. Yours seems to go much further than mine though.
The idle looks a bit on the lean side and again it sweeps a lot more than mine does at idle.
I would bet barring no leaks or bad parts, it's tune related.
Old 05-05-2022, 03:57 PM   #10
CamaroDreams76
The daily driving and idle seem fine. Idle I'd say mine sweeps way more than that. As far as WOT goes, thats a far sweep. I saw 11.9 at one point to 13.0.
Where is the wideband sensor and is the bung and all at the proper angle? It is a possibility that its the tune
Old 05-05-2022, 05:06 PM   #11
Nate2SS
Nate2SS's Avatar
The wideband is welded right at the end of the long tube. The angle seems to be right. regarding the WOT, would you say a vacuum leak would cause this and not impact the regular driving and idle? I guess cause the leak would be lower given the RPM.
I'll send the videos to the tuner and see what he has to say.
Old 05-05-2022, 08:52 PM   #12
demonspeed
demonspeed's Avatar
Drives: Camaros
From my understanding, the angle is only to ensure condensation doesn’t accumulate. Anywhere from 91* to 180* is fine for bung positioning.[/beavis&buttheadlaugh]
10/13/22: 1100
Old 05-05-2022, 10:53 PM   #13
Nate2SS
Nate2SS's Avatar
Bingo, the bung is welded at a big enough angle that I don’t have to worry. I had a defective sensor out of the box but since replacing it’s been operating, numbers are just off
