Old 05-05-2022, 05:44 PM   #1
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
103mm TB on a factory LS3 manifold - what's it worth? Definitive dyno results inside
Hey folks - happy Cinco de Mayo. At GPI we get asked about porting factory LS3/L99 manifolds out to accept a 103mm throttle body pretty frequently. We don't offer that service because we've always thought it doesn't actually help add any significant power, but we've never truly put it to the test. Last month we went ahead and did test this. The bottom line, for the guys that don't wanna read, is that the 103mm throttle body is worth NOTHING on the stock manifold.
If you're into the details, have a look. I've got it summarized in a video on my YouTube as well.
https://gwatneyperformance.com/103mm...ow-much-power/
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-06-2022, 02:28 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Very nice test. I've been wondering about the exact same thing. I would have thought that it would have picked up something but I guess the dyno doesn't lie. Thanks for the info as always, I'm sure everyone is very grateful for you guys.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-06-2022, 07:19 AM   #3
acammer
acammer's Avatar
Yea - it's a test a lot of us have always talked about, but I've never seen done and documented. I wish we had more time to mess with stuff like this - we definitely are always trying to gather more information.
I'm pretty sure the restriction is just the manifold itself, and the throat specifically. If you look at the opening, especially once it's ported out, you can see that predominately the roof, but then also the sides of the throat all neck down right behind the throttle body flange, and I'm pretty confident that negates any sort of flow you can add right there at the throttle body.
Old 05-06-2022, 08:49 AM   #4
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Don't people usually remark on improved throttle response as being one of the draws of the TB upgrade? Personally I haven't noticed any substantial improvement in throttle response, but mine doesn't have the stock manifold either and also had the heads ported, so I don't have apples to apples comparison or anything, and just have the 102. Good write up!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 05-06-2022, 10:01 AM   #5
acammer
acammer's Avatar
So, yes - porting an OEM throttle body is not really about gains much in terms of actual flow - the purpose is mostly to kill the ledge behind the blade opening, to improve response when you crack the throttle. You could accomplish that with a 102, but that's a much more costly way to achieve the same result.
