Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 05-07-2022, 11:11 PM   #1
Aw409
Drives: 2012, Chevy, camaro, ss
BIG BRAKE KITS FOR TRACK
What are you guys running for a big brake kit at the track, I’m in the market and would like to see what others people run on their cars
Aw409 is offline   Reply With Quote
Old 05-08-2022, 03:29 AM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Six pistons Z06/ZL1 and cooling ducts. These are heavy cars and they need whatever help they can get.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 05-08-2022, 02:52 PM   #3
Aw409
I have heard the zl1 kit is a popular option. What about after market kit such as wilwood, bear, or brembo? Also what is a good option for brake ducts
Old 05-08-2022, 06:12 PM   #4
demonspeed
demonspeed's Avatar
Drives: Camaros
I believe most people find the ZL1 brakes with a race pad (of which there are many options depending upon driving style and need) are all that’s necessary. Don’t forget upgrades hoses and fluid, of course.
The only duct kit that I’m aware that still available is the Z/28. Even that I believe needs pieced together at this point. Otherwise, one needs to make their own. Take a search through this section and members’ build threads and you’ll find plenty of examples.
10/13/22: 1100
Old 05-08-2022, 08:48 PM   #5
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
I went with the Z06/ZL1 upgrade on my 1LE.
Wjlwood, bear and the other make very good products, however I wanted simplicity. What I mean by this is if I need any brake part I can get it at the local auto parts store. I you use aftermarket you have to order the parts.
This might not seem like an issue to many but if I'm at the track and need to replace my pads then it becomes one.
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 05-09-2022, 06:41 PM   #6
FASTFATBOY
Drives: 2013 ZL1
Brake pads are the most important thing along with fluid, you'd be amazed at how capable the stock stuff is with Raybestos ST43 or ST47 pads and ATE fluid
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 05-09-2022, 11:09 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
An if you can score a set of rotors from a 6th Gen 1LE special brake package they are directional (left/right specific) slotted and vented I run them on my 5th Gen.
Orange Krush II
Old 05-10-2022, 11:28 AM   #8
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
If you order the Z06 brake upgrade part by part, you will save A LOT over a full kit.
I used Nick S.'s list here, 3rd post down:
https://www.camaro5.com/forums/showthread.php?p=8744227
I also did my own DIY brake system cooling as well with ducts and tubing off Summit.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 05-10-2022, 05:36 PM   #9
Aw409
I appreciate all the feed back, I think I will look into upgrading my stock pads to some race ones and some vented/ slotted rotors ( I already swapped over to RBF 600). After I wear those out I will probably look into the z06/zl1 kit. Probably will end up fabing some vents too
Old 05-10-2022, 07:56 PM   #10
demonspeed
demonspeed's Avatar
Drives: Camaros
I wouldn’t bother upgrading rotors as you’re going to get the improvement from the pads.
10/13/22: 1100
Old 05-11-2022, 07:59 PM   #11
FASTFATBOY
Drives: 2013 ZL1
Stay with plain blank rotors, you don't need the hard parking rotors, they crack and fail. With the correct pads you don't need cooling, they want to be hot and stay hot....but not too hot. It will be quite some time before you need those. As of late air deflectors mounted on the control arm have been proven more effective than cooling ducts.
As a novice(it appears you are) you are overthinking it. Put some Raybestos ST43 pads on the car with some Centric premium rotors, bed in the pads, put on some cheap tires and go have a ball. At this point that's all you need as far as car changes.
Track time makes you faster in this realm, not mods.
