Old 05-08-2022, 12:41 AM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Oil pressure
This is my car cruising on the highway. This is the oil pressure. Does this look normal? I also noticed that it will go down to 27 when at idle. On the street at just normal 4th gear 45mph it will be a little above 30 or a little below. Should I be worried? It has 89,000 miles it is a 2012 2ss ls3. Do all the other gauges look right?Name:  IMG_2541.jpg
jesse121pm is offline   Reply With Quote
Old 05-08-2022, 12:56 AM   #2
Camaro fanboy
Camaro fanboy's Avatar
Drives: 2017 2SS Arctic blue fully loaded
they all look good to me
Camaro fanboy is offline   Reply With Quote
Old 05-08-2022, 01:58 PM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Looks correct. Those numbers are right about where my car runs for pressure, as well.
0stones0 is offline   Reply With Quote
Old 05-09-2022, 01:34 AM   #4
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I think your ok with those numbers. Mine is 32psi at idle and 50psi at cruising but I have the 10355HV pump with 167k on mine.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-09-2022, 06:39 AM   #5
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
looks normal
FasNuf is offline   Reply With Quote
Old 05-09-2022, 06:49 AM   #6
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Normal.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
Old 05-09-2022, 02:55 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Looks normal for a stock pump. Mine sits at 39-42 at hot idle, 54-56 at cruising at 2k rpm's, and around 65-68 at WOT, but I have the Melling 10295 pump in mine with 27k miles on the build. I have the Aeroforce Interceptor twin gauges to monitor all my engine parameters.
Old 05-10-2022, 07:23 AM   #8
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Using the "old school" rule of 10psi per 1000rpm, you really only need 7 psi at idle. As a matter of fact, the "stop engine-oil pressure low" message on the driver information center comes on at 7psi. Also most people don't know that there is a filter screen under the oil pressure sensor on the L99 to protect the solenoid valves in the VLOM. If that becomes restricted it will cause erratic and erroneous readings on your gauge.
NOT A 45 is offline   Reply With Quote
Old 05-10-2022, 07:35 AM   #9
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
I have same pressure 🙋
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 05-10-2022, 07:36 AM   #10
George-CZ
George-CZ's Avatar
Sorry... Message from phone 🤦
Old 05-10-2022, 09:24 AM   #11
DavidH
DavidH's Avatar
Drives: 2010 Camaro 2SS
Mine under hot idle is right around 27-30psi and 30-35 cruising. Yours is higher than mine so I'd say you are good!
DavidH is offline   Reply With Quote
Old 05-10-2022, 03:25 PM   #12
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
Remember also the pressure will vary depending on the brand of oil you are using and the weight. The thicker the weight oil the higher the pressure will most likely be.
MIKZ28 is offline   Reply With Quote
Old 05-10-2022, 05:49 PM   #13
sdynak
Drives: 2014 ZL1
I don't know.. my suggestion is to give it to me before anything bad happens to be on the safe side Just looking out for ya pal .
2014 ZL1 Black All OEM, Manual
SOLD: 2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 05-12-2022, 06:13 AM   #14
George-CZ
George-CZ's Avatar
Yesterday's values idling after 30 min. driving
oil, oil pressure, temp
