Old 05-10-2022, 08:48 PM   #1
Jackman0112
Jackman0112's Avatar
Drives: 11 Camaro 2LT、12 Camaro ZL1
I fixed the noise problem of the NPP exhaust
For a long time, the NPP exhaust pipe often makes metal vibration noise. Today, I finally fix this problem and share it with you.
There are two pull caps (at the yellow arrow) under the exhaust pipe. I pull them out after they are damaged, and then weld the holes. These two pull caps are more like drainage holes, but it is the main problem of noise.
I will weld this hole because there is also a drain hole at the silencer. If you are troubled by this noise for a long time, you can try this method.
Jackman0112 is offline   Reply With Quote
