![]() Drives: 2013 Victory red/white stripes SS Join Date: Mar 2013
Bilstein B6 change ride height?
I am needing new rear shocks on my 2013 SS and am wanting an upgrade over stock. I am interested in the Bilstein B6 but am confused an whether or not they will affect my ride height. I am not lowered and I like my ride height where it is at. I recall a thread about having to machine 0.5 “ off of the mounts to maintain ride height… confused as to if that would pertain to my situation or not.. any help or info would be greatly appreciated… thanks guys!
FaSSteddie Last edited by faSSteddie; 05-11-2022 at 04:34 PM. Reason: corrected Bikstein to Bilstein |
![]() Drives: G8 Join Date: Mar 2012
Shocks don't change ride height, springs do. Coilovers blur this line a bit but that's another situation.
Sent from my Pixel 4 XL using Tapatalk |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
This is the thread he is referring to. I'm not sure that I agreed with him that the extended length of the shock being different with no load would cause additional preload. In my mind this would only be true if the shock length with load was less. It would not allow as much droop in the suspension though.
https://www.camaro5.com/forums/showp...1&postcount=42 Last edited by gtstorey; 05-11-2022 at 03:13 PM. |
![]() Drives: 2014 Camaro SS Join Date: Jan 2019
The bilsteins don’t do anything to change ride height. You can also disregard that thread as I believe it’s applicable to the 1LE only.
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
1LE has same springs as the SS.
Orange Krush II
#6 |
Same springs different shocks/struts.
#7 |
![]() Drives: 2015 Camaro SS/RS 1LE Join Date: Jun 2016
#8 |
![]() Drives: Chevy Camaro Join Date: Feb 2023
Measure your shock like the link shows and adjust as necessary. I had to machine the rear Bilstein spring mounts for my 1LE just like the link described.
