Old 05-13-2022, 08:04 PM   #1
Blubird68
Drives: 1993 z28/2010 2SS
PCM tuning question
If I were to buy another PCM, would it have to be flashed for the VIN ? Or could I just install it and load a tune ? Wasn’t sure if they were vin locked
Blubird68 is offline   Reply With Quote
Old 05-16-2022, 07:59 AM   #2
14Camaro2ssRS
Drives: 2014 Camaro 2SS/RS M6
can't just swap an ECM... it needs to have your VIN, needs to be synced to BCM, and TCM if you have an auto transmission, other modules, etc...
14Camaro2ssRS is offline   Reply With Quote
Old 09-04-2022, 12:14 PM   #3
Marozl1LE
Drives: Camaro gen 6 zl1 1le
what about the engine hours on the speedometer ? if i put a another ecu ??
the hours are not transferred from the ecm to the speedometer, so if you have installed a used ecm, it has a different running time than the speedometer or not ?
edit : sry i was talking form camaro 6 i see im in wrong forum sry but if anybody can answer my question that will be nice too thanks guys for your support
Marozl1LE is offline   Reply With Quote
