![]() Drives: 2015 camaro Join Date: Mar 2020
Rattling noise from trans when clutch is pressed
My 2015 camaro trans makes rattling noise when I depress the clutch before shifting from first to second gear. It has been doing it since 74000 miles. Now, it's 103k miles. I called GM when it was at 74k miles, Chevy said that since the noise occurred when the clutch was depressed, any clutch work would not be covered under the power train warranty. They said that page 5 of the user manual clearly stated so. I go, who the phuck read user manual of a car for warranty info before buying it? GM sucks. They have no concepts of customer satisfaction and quality control. This will be the last GM car I'll buy. If your car has the same issue and has been fixed, please let me know what the problem really is and how to fix it. Thanks!
![]() Drives: 2013 L99 Join Date: Jan 2019
Probably throw out bearing. Whatever it is I can’t imagine it can be fixed or even diagnosed without changing the clutch. I would wait until clutch needs to be replaced.
| Tags |
| clutch, rattling noise |
