05-16-2022, 09:45 AM | #1 |
Drives: 2016 Camaro SS Join Date: May 2022
How do I determine my trim level/package?
Good morning, everyone. I apologize in advance for the "noobie" type question, but I bought my Camaro secondhand and didn't get a ton of information on it. What I know is that I have a 2016 Camaro 1SS, but I'm not sure of the actual trim level.
The particular reason I'm hoping to find out is I'm in the middle of upgrading my sound by adding a 3rd party amplifier and subwoofers, but I'm connecting to my rear speakers and they don't seem to be getting a signal (no sound/vibrations coming from either side. As a result, no sound to the 3rd part amplifier and subs. To test, I connected the amp and subs to a separate car and they worked properly. My original thought on the suspect issue was the OEM amplifier having a bad channel or similar. But, in reading on these forums, I'm seeing the 1LE trim does not have an OEM amplifier. Before I go buying a replacement, I'd love to know if I have one at all without tearing apart my car again. So, easiest way to tell? Any tell-tales signs that differentiate? Thanks in advance! |
05-16-2022, 10:09 AM | #2 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
trim level is 1SS.should be a cloth interior,no backup camera and probably a few other details im not sure of.i believe theres a listing under the trunk floor where the spare tire is that will list what equipment you have on your car,but cant help with the radio question.
05-16-2022, 10:18 AM | #3 | |
"***UPDATE 1/21/19*** There is no external amplifier in the 1SS 1LE. It has a chip amp integrated into the HMI which is located under the glovebox. You can see the location at 6m24s in this video (although the Camaro in video is not a 1SS 1LE, all 6th gens have HMI mounted in the same location):" |
05-16-2022, 10:48 AM | #4 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
05-16-2022, 10:50 AM | #5 |
Drives: E92 BMW M3 Join Date: Oct 2012
Required by law on all cars at this point aren't they?
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
05-16-2022, 11:10 AM | #6 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
since 2018.
05-16-2022, 11:21 AM | #7 |
my bad.mines a 2015 so it had to be a 2LT to get the camera.
05-16-2022, 11:53 AM | #8 |
Drives: 2022 VOM 2SS 1LE M6 Camaro Join Date: Nov 2021
Pictures of the outside and inside would help a lot. You already know the actual TRIM level (which is 1SS of course). After that, it's literally just random options attached to it.
You'd know if it's got the 1LE - it'd have giant freaking brakes, wheels, and tires. Nevermind all of the matte black accents on the outside.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500 20211208 - 3000 (TPW: was 20220103, now 20220124) 20211220 - 3400 (TPW: 20220110) 20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle) 20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223) 20220212 - 4800 --- 20220216 - 6000! 2024 Silverado EV RST First Edition on reserve, as well. |
05-16-2022, 12:16 PM | #9 |
05-16-2022, 12:22 PM | #10 | |
How do I know? Because GM cheaped out on my 2019 3500 dually, and didnt include tire pressure sensors...because it just barely broke 10K lbs GVWR. The 3500 single rear wheel is below 10K lbs GVWR, and got TPMS
05-16-2022, 12:40 PM | #11 | |
Below are some pics of my exterior. Note, the black rims are the standard 20s that came on the vehicle, just powder-coated. Based off what you've said, I'm assuming I have the non-1LE which in turn should mean I do have an amplifier based on what I've read here. |
05-16-2022, 12:43 PM | #12 |
Long hauler
For the 6th gen, backup cameras are on every car, no matter the configuration.
1SS - Cloth seats 2SS - Leather seats, Dual Climate Control Anything else is packages I believe, if you have Bose speakers then you have the Bose Amp in the back under the trunk. Otherwise, you have no additional amp with the stock speakers. I have read that the stock speakers are easier to change out and the Bose Amp is more difficult to change out.
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6 - Totaled Happiness: Infinite |
05-16-2022, 12:45 PM | #13 | |
Long hauler
Can probably list what packages it has with interior pics, or if you take a picture of the RPO code sticker in the trunk under the floor mat then that lists every option the car has
05-16-2022, 01:04 PM | #14 |
Nice color.
Looks like a standard 1SS build - the silver wheels (originally, I assume you painted them) are a good sign it doesn't have a bunch tacked onto it.
