05-17-2022, 01:59 PM | #1 |
Drives: 2018 ZL1 Join Date: May 2022
ZL1 Hood Insert
Hi
If you undo all the bolts under the hood that hold the carbon insert in can that whole piece be removed leaving a hole ? Also anyone at the part numbers for all those 10mm bolts? |
05-17-2022, 06:42 PM | #2 |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
You might want to try the 6th Gen forum, as the 5th Gen doesn't get much traffic. Other than that I don't know about the 6th Gens.
06-03-2022, 09:54 AM | #3 |
Summit White 2012 ZL1 M6
Drives: 2010 BLACK 2SS/RS M6 Delvd 8/24/9 Join Date: Jul 2008
the answer is yes the carbon fiber scoop will remove. But you can't buy a new one without purchasing a new hood for 3Kish... So be careful with it worth it's weight in gold
2012 Summit White ZL1 Manual 6sp Blk 10 spoke, "Thanks Champion Chevrolet" delivered 6/9/2012 #1588
