@LS.ACE
Drives: 2014 Chevy Camaro 2SS/1LE Join Date: Jan 2017
FS: Factory M6 Driveshaft
As the title states I am selling the following items from my 2014 Camaro 1LE. The reason for selling is I left my car at a shop that ended up closing down and selling my transmission on me before I went down to pick it up, owners have since gone ghost. Due to all of this I will finally be pulling the trigger on the th400 swap I have thinking about doing forever. The driveshaft I am guessing was symbolic of the literal shaft the shop gave me by stealing my transmission lol
Factory SS M6 Driveshaft- $175 (Local Pickup Preferred) From an SS- P/N 92246788McLeod RXT 1200 Clutch w/ Flywheel - SOLD! Located in North Jersey- Morris Plains area. Willing to ship the flywheel, message me if interested.
Some weird snail with a belt on it
| Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials |Last edited by TheInfamouSS; 05-23-2022 at 12:53 AM. |
![]() Drives: 2010 2SS RS Join Date: Mar 2017
PM’d regarding the clutch & flywheel.
GPI Sales Consultant
If that MM6 1LE trans turns up - lemme know!
Got a question about a GPI product? Feel free to shoot me a message! |
@LS.ACE
As much as I would love for that to be the case, coming u on a year now I do not think that will ever be showing up. The owner is hiding somewhere in the bushes tuning on IG.
| Tial Q Bov | CCP Jam Cam | Stainless Works 1 7/8" Headers to Custom 3" Exhaust | Alky Control Dual Nozzle| ProMeth Trunk Mount Tank | Melling Oil Pump | DSX Aux Pump | id1050x Injectors | McLeod RXT w/ Monster Billet Release Bearing | ZL1 3.73 Rear Diff | BMR Delrin/Poly Diff Bushings | DSS 1-Piece Aluminum Driveshaft | ZL1 Axles | Metco Driveshaft Loop | BMR Adjustable LCA's, TA's, Toe Rods | BMR Adjustable Sway Bar w/ Fe3 End Links | Mickey Thompson 305/35-20 Street S/S Drag Radials | |
