Opinions. Used camshaft
Like the title says.
What are your opinions on used camshafts. Would you buy one. Just remember many years ago, the lifters would create a wear pattern on the cam and reusing would cause issue with either the cam or the new lifters... JUst curious..
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I’ve bought and sold used cams. I’d have no issues running so long as it checks out ok.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
How many times are you going to open up the block to replace a cam or lifters? Hopefully only once lol. So why save on a few bucks and just buy new imo.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
![]() Drives: TBS BLOWN/CAMMED 2010 CAMARO RS/SS Join Date: Jul 2021
NEW Only , warranty and ease of mind !
![]() Drives: '11 2SS/RS LS3 M6 (Sold) Join Date: Dec 2015
I would buy new. Multiple shops have their cams made by the same manufacturers and not too long ago those manufacturers were having issues with metallurgy and failing cams. 8620 cores and a good company is what you want.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. |
#6 |
Started#gottalovethatblue
No thank you. The risk isn't worth the reward in my opinion.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
If you do your own work, not that much to be afraid of as long as you can see what you're getting before you pay for it. If you pay someone 3k to swap a cam, not that much savings for you. I bought both the cams in the turbo car and the vert used. It all depends on your intentions and how close to the ragged edge you are running. It's not like the old flat tappet days. These cams are all roller so not a lot of wear.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I just put a used cam in my mom's truck.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
#9 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I might use one on a throw together build, but not anything nice. I'm swapping mine now and I'll keep the one in there, but I wouldn't buy a used one for my stuff. Like already said, it's cheap, why skimp on it?
#10 |
It’s not like they are items where you’ve got a finite life where they need replaced. It’s literally just a piece of machined metal - it’s either still good or it isn’t.
#11 |
![]() ![]() ![]() ![]() Drives: 2015 1LE Join Date: Oct 2015
Only if the lobes look really nice.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
#12 |
Drives: 2010 2SS/RS Join Date: Feb 2020
