Old 05-18-2022, 06:42 PM   #1
Thunderstick
Thunderstick's Avatar
Drives: 14 Camaro LS
My 1LE ate a Pushrod
My 2014 1LE had a bit of ticking on Sunday morning when I started it. I kept my ear on it and thought about what it could be. First stop of my errands I checked the oil. Full as usual since I'm religious about only one thing, my car. In between second stop the ticking got super rapid and then disappeared altogether and simultaneously the check engine, service stabilitrack showed up. I got it towed to the dealer and they have reported that the pushrod in cylinder 5 went for a trip. They found it via scope (I'm guessing since they hadn't pulled the heads) hanging out horizontal along a head stud. So far I'm being quoted between $1400 and $3800 unless they find more damage. I'm hoping for the best!!!
Sent from my SM-S908U using Tapatalk
Thunderstick is offline   Reply With Quote
Old 05-18-2022, 06:57 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
For that price I would go to a performance shop and do a cam package for the same price.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 05-18-2022, 07:26 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Yea. If this gets expensive you need to pause and consider your options.
Old 05-19-2022, 02:01 AM   #4
SS 310H55A
Drives: 2014 Camaro SS
What would have caused this to happen? Is this fairly common on the LS3?
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 05-20-2022, 02:43 PM   #5
Thunderstick
$2418.01 out the door. Lifter in Cylinder 5 collapsed taking everything else with it but no other damage. I'll be picking her up tomorrow morning.
Old 05-21-2022, 12:49 PM   #6
Thunderstick
The bill.
Old 05-21-2022, 06:09 PM   #7
Thunderstick
If anyone could tell me if there is a break in schedule that would be great. My service advisor went on vacation right after he gave me the $1400 - $3800 estimate. There was silence for a day and a half and all of a sudden the car was done. She is right back to normal but I would love some advice as to how this possibly happened and what I can do so it doesn't happen 7 more times. Thanks all!
Old 05-21-2022, 06:27 PM   #8
WVracer
WVracer's Avatar
Drives: '11 2SS/RS LS3 M6 (Sold)
It was a faulty lifter, nothing you could've done to prevent it. It doesn't look like they replaced the camshaft. No break-in is needed. I would change the oil after 500 miles personally. You never know what junk got into the motor from the new parts or the shop while they were working on it.
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs.
WVracer is offline   Reply With Quote
Old 05-21-2022, 08:00 PM   #9
Thunderstick
Thanks for this! I appreciate you and this forum.
Old 05-25-2022, 09:57 AM   #10
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
The bill.
I've been a dealership technician since 1984...it's bad ju ju to disparage someone else work, but I will tell you this. I can tell by looking at the parts used that you have a LS3. I work in a high volume shop, and specialize in Corvette. The only lifters we have a problem with collapsing are the AFM lifters, never the standard lifters the LS3 uses. I have replaced numerous bent push rods in the LS3 Corvettes and Camaro's and have never had to replace a lifter as a result or cause. I'm going to assume that you had a inexperienced tech (which are plentiful these days) working on your car. The reason I make that assumption is that there is a bulletin concerning the LT style V8 for 20-21 trucks that bend pushrods due to a collapsed AFM lifter.
I'm pretty confident I could have fixed you with nothing more than a pushrod, valve cover gasket and possibly a oil change!
NOT A 45 is offline   Reply With Quote
Old 05-25-2022, 10:37 AM   #11
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
I’ve bent several LS pushrods over the years, and just can’t fathom how one would have ended up doing what the OP is explaining the diagnosis was. Replacement is simple just like you said - pull the coil rail, valve cover, and rocker(s). Drop new pushrod(s) in and button back up. I even reused my gasket and didn’t change the oil
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 06-16-2022, 05:30 PM   #12
Thunderstick
That's the info I was given. What you're saying makes me wonder but at this point what can I do?
Old 06-16-2022, 05:33 PM   #13
Thunderstick
Is it possible a bent pushrod under heavy load could do something to a lifter? I had a ticking and it got super loud and then stopped and that's when the bells and whistles activated.
Old 06-16-2022, 07:35 PM   #14
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
I would gather that the pushrod started bending and then bent enough that it snapped. That's why it started out a small tapping and gradually got louder as it bent more and more till it broke.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
