Old 05-20-2022, 01:47 PM   #1
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
TPMS Bypass
I ran the search and can't believe this hasn't come up before. I, like most on here, have two sets of wheels for my Camaro. I'm tired of tire monitors. I had a plan to put all 4 in a PVC pipe, pressurize it and put it in the trunk. Been dragging my feet on doing it just because I would have to get the monitors out of my current stock rims or buy new ones.
Well the time is now. I have had my 2010 since it's birth and one of the TMPS has finally died. So I thought time to do a delete. As I'm messing around on the internet I found a little box, called a TMPS Bypass. I pulled the trigger and ordered it. Seems to easy if it works. Set up is a push of the button a few times and then just throw it in the glove box.
Once I get it I will post pics and a little summary of how good it works or doesn't work.
More to come!
Lnch Mny is offline   Reply With Quote
Old 05-20-2022, 02:04 PM   #2
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
camguynj is offline   Reply With Quote
Old 05-20-2022, 03:55 PM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Subscribed!
0stones0 is offline   Reply With Quote
Old 05-20-2022, 05:36 PM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Oh nice! Sounds too simple but looking forward to the review.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 05-20-2022, 06:58 PM   #5
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Subbed !!!
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 05-20-2022, 07:49 PM   #6
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Wouldn’t it be easier to buy some Tpms sensors for the extra wheels and call it a day. I also have two sets, both with tpms sensors.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 05-21-2022, 07:07 AM   #7
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
I just press the button and live with the dash icon.
If you think the Camaro system is screwed try the Pontiac G8 reset
Like I said the icons nots so bad.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 05-21-2022, 11:55 AM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ This is what I did. They don't cost that much to buy..
Old 05-23-2022, 10:04 AM   #9
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
More to come!
https://tpmsbypass.com
I have tried it, it doesn't work in 2010
Only Camaro 2013-2020 are compatible with this box.(Sales & Customers Support
SRSDRIVE LTD - TPMS BYPASS)
https://www.ebay.com/str/futurzenith
I have tried this too, it doesn't work in 2010.
I'll try this next.
https://spooftpms.com/us-gm-1-family-tpms-simulator/
Old 05-24-2022, 11:24 AM   #10
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I think this is the one I ordered. It says 2010 compatible. I guess if it doesn't work I'll send it back. Did it not even register?
This part is compatible with 1 vehicle(s) matching 2010 Chevrolet Camaro SS Coupe 2-Door 6.2L 6162CC 376Cu. In. V8 GAS OHV Naturally Aspirated. Compatibilities are defined by the seller for vehicles typically fitted for operation within the original listing country.
Figured to good to be true.....
Old 05-24-2022, 11:44 AM   #11
chevy pilot
Yep,but lost all sensors after 15 miles.
I sent it back and got the money.
Old 05-24-2022, 12:46 PM   #12
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
I did that exact thing but the sensors I bought had a 1.5” black valve stem that just didn’t look good with my new brushed aluminum wheels. So I bought new valve systems and tire shop said I couldn’t attach them to the sensors….so I opted to remove the sensors and deal with button pushing. Seeing this thread I thought would be an awesome fix for my situation since I still own all 4 of the brand new sensors. I’ll see if this works when he gives us updates.
Here’s the extra long blk valves that was on before.
Now here’s the new replacement sorry this pic is not a close up but you all should get the idea. It completed the look now I’m just waiting to see if someone can come up with a fix.
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 06-05-2022, 03:20 AM   #13
chevy pilot
The first device that works
Old 06-06-2022, 01:11 PM   #14
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
So far so good.... I bought the one linked below from ebay and a battery pack from Walmart. It was super easy to set up, zip-tied together, and put it in the glove box. It shows all 4 tires at 34PSI. The next day it was still good. Drove it again a few days later and still holding. I have just been driving around town, so I figure the real test will be going to Kentucky. Well would NOT recommend. After 10-15 miles the system rest and the tire late came back. I will say it worked for just going around town fine. I’ll be returning for a refund.
https://www.ebay.com/itm/16284479844...ally+Aspirated
