Old 05-23-2022, 06:00 PM   #1
Royal Tiger
Drives: 2013 2SS/RS Convertible
LED brake lights
Thoughts on these?
Royal Tiger is offline   Reply With Quote
Old 05-23-2022, 07:31 PM   #2
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Rice
joshnmn is offline   Reply With Quote
Old 05-23-2022, 08:35 PM   #3
Royal Tiger
Do you have any suggestions on something LED or brighter than stock? Looking to black out the taillights to match the rest but want decent visibility.
Old 05-24-2022, 08:17 AM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I have a friend who has a set of those, and he says they aren't very bright at all. He is going to reinstall his Technostalgia's he has, like mine. Love them, but they are expensive, and I think only Rick's Camaros / Ecklers sells them anymore.
Old 05-24-2022, 08:50 AM   #5
Royal Tiger
I was thinking of the dark out covers from Phasetech and the XP80 red LED’s they offer.
Old 05-24-2022, 10:07 AM   #6
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
With the darker RS housings, I just replaced the halogens with these:
https://www.vleds.com/shop-applicati...it-r-3157.html
Kind of expensive, but easily 3x brighter then stock.
If you go for dark tinted taillights, these should shine right through just fine.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 05-24-2022, 10:30 AM   #7
joshnmn
2&THEHIT
joshnmn's Avatar
Leave the red lenses, you need the contrast, IMHO.
Old 05-24-2022, 01:48 PM   #8
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
I tinted my rear with phastek darkest vinyl overlays and installed hed bulbs and they are still bright.
Or get the nori lights
https://norilights.com/products/infi...t-modification
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 05-24-2022, 02:53 PM   #9
SaReNi
Drives: 2012 SS
I just did led bulbs in mine to make them brighter.
2012 Camaro SS
SaReNi is offline   Reply With Quote
Old 05-24-2022, 04:16 PM   #10
Royal Tiger
Thanks all. Looks like the black out overlays and LED’s for the win.
Old 05-24-2022, 09:40 PM   #11
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Same here.
Old 05-25-2022, 01:15 PM   #12
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
My tails are sprayed with a mixture of 8 parts GM black and 2 parts clear. They are pretty black and my tails shine through perfectly even in daylight. Never even thought to put brighter bulbs. I may be cutting mine open soon to do the afterburners so maybe Ill look into some LEDS at that point. I dont think the LEDS will play well with my sequential tail harness tho
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 01-23-2023, 09:26 PM   #13
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So I have a tinted set of tails with LEDs an they are extremely bright but now when the blinkers are on or when I hit the brakes it screws with radio reception. Anyone have any ideas??
Orange Krush II
Old 01-24-2023, 02:07 AM   #14
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Do they light up the lense evenly like the eom bulb or is there a bright spot where the led bulb is?
camguynj is offline   Reply With Quote
