Old 05-23-2022, 10:40 PM   #1
Bigalamo
Bigalamo's Avatar
Drives: 2011 LS Camaro
PS pressure hose // oil in runners
I was looking in the engine bay and saw that this pressure hose is unsecured and laying across the other hoses. It has a mounting screw, but I can’t tell where it goes? Does anyone have a pic of theirs for reference? Thanks.
Oil in runners: I took off the plenum cover to paint and looked at the runners. I have an elite engineering catch can hooked up, as well as a clean side separator. I was wondering if a light coat of oil in the intake manifold is normal even with this setup.
Also, here was the outcome of the painting. Going to do the throttle body, IM and valve covers soon too.
Bigalamo is offline   Reply With Quote
Old 06-08-2022, 09:19 AM   #2
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
2010-11 V6 and V8 cradles are the same. Pictured is a V8, but the attachment should be the same. It is your power steering hose. The other 2 hoses are for the transmission cooler. I would think the power steering hose would go under the trans hoses. You may be missing a piece or it is broken for the p.s. hose mount.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 06-08-2022, 06:58 PM   #3
Bigalamo
Bigalamo's Avatar
Thanks for the info! Going to remount.
