Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Southwest
Old 05-25-2022, 05:54 PM   #1
daktah
daktah's Avatar
Drives: 2013 camaro 2ss 1le
mods n smog in vegas
just curious how smoging in las vegas goes for those of you with more obvious mods like cams and longtubes since techs are supposed to take a peek under the hood. id like to make moar powah but id also rather not have to find a shop to bribe or do a cam and header swap every year just to drive my car.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners
daktah is offline   Reply With Quote
Old 08-24-2023, 01:21 PM   #2
Jersey
Jersey
Jersey's Avatar
Drives: 2010 cammed n supercharged SS
Did you ever get your answer? I am moving out to Vegas next month and was just wondering the same thing. Please let me know. Thank you!
-PFADT SUSPENSION
-1.25" Drop Springs all around, -Front and Rear Sway Bars,
-Sway Bar End Links, -Rear Tie Rods,
-Rear Trailing, Arms, -Subframe Bushings,
-Polyurethane Diff Bushings, -RUCA Bushing w/Bracket,
-GForce 1400 HP Outlaw Axles-Manley Hardened Pushrods,
-McLeod RXT Twin Disc Clutch kit with Aluminum Flywheel
-MGW Short Throw Shifter,-Ati Balancer LS3,
-MSD Boost-A-Pump w/vacuum line,-Fast 65# injectors LS7,
-MTI Racing Stage 3 LS3 Camshaft-231/243,
-valve springs, retainers, valve seals, cam sprocket,
-Stainless Works Long tube headers with CAT delete,
-F1-A Procharger
Jersey is offline   Reply With Quote
Old 08-25-2023, 03:04 PM   #3
daktah
daktah's Avatar
  • no underhood or underbody inspection was performed
  • drove beforehand to get everything hot (so the cats are working as well as possible)
  • closed the npp so it sounded stock and minimized suspicion
  • drove in very gently to minimize exhaust output (cats get overwhelmed anywhere above idle)
  • did it on a day with at least a mild breeze to blow away any stank that the cats missed
passed without a problem. note that i still dont have a cam however so cant attest to that portion.
