Old 05-25-2022, 08:28 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Rear End Upgrade
Everyone is telling me to get a 9 inch kit but they are $8000. What is a better alternative to upgrade the rear end of my 2012 2ss. Im looking for it to support 800whp
jesse121pm is offline   Reply With Quote
Old 05-25-2022, 08:41 PM   #2
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Hendrix offset differential bushings and a Truetrac. Otherwise, ZL1 rear.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 05-25-2022, 09:17 PM   #3
Royal Tiger
Drives: 2013 2SS/RS Convertible
I’m running an Eaton TruTrak with 3.91’s.
Royal Tiger is offline   Reply With Quote
Old 05-25-2022, 09:38 PM   #4
RS/SS '10
Drives: 2010 2SS/RS
I am never going to be in the 700+ rwhp, so I am not going to mention my GM 3.91 with LPW cover.
RS/SS '10 is offline   Reply With Quote
Old 05-25-2022, 10:38 PM   #5
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
I have cradle bushings, offset diff bushings, stock diff with DSS axles. Prob will go True Trac soon.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 05-25-2022, 11:42 PM   #6
jesse121pm
jesse121pm's Avatar
I still want to be able to slide it will that still be possible?
Old 05-26-2022, 12:48 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If you are an auto, you can probably find a ZL1 3.23 fairly cheaply. With drive shaft and axles can be done for well under 3k. 3.73 units are getting hard to find.
Old 05-26-2022, 01:18 PM   #8
Royal Tiger
With almost 800 wheel, all she does is slide.
Old 05-26-2022, 01:44 PM   #9
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
Eaton tru-trac and GM 3.91 gears here as well. I'm not at 800 but good to see it can support it. Axels are next for me.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
diff, rear end
