![]() Drives: 2010 Camaro 2SS Join Date: Jan 2019
Car bogging and stuttering around 2,200 Rpm
Just got Corsa Sport zl1 quad exhaust installed on a 2010 camaro ss automatic about 2 weeks ago and the car is starting to bog and stutter around 2,200 rpm and I can feel vibration under the floorboard when idling. The car has TSP 1-7/8” catless headers, JLT intake, BTR Stage 2 cam and a 3,200 converter Stall.
Is it throwing codes? Check engine on?
Life is short, drive it like you stole it! ![]() |
There’s not any codes or check engine light
It’s idling a little rough and smells like gas
Might be a bad injector
#6 |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
You sure your tuner didn’t turn off any of the mil lights in the tune. If you have hp tuners you should check it out.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
#7 |
I don’t think the tuner turned off any lights I just recently had a couple for a bad alternator.
| Tags |
| cam, engine, exhaust, help me, tune |
