![]() Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
WTB: Kooks Off-Road Connection Pipes
Shot in the dark here, but does anyone have a set of Kooks Z28 Off-Road Connection Pipes they don't need (3" X 2.75")? Kooks Part # 22513100. They are on back order from Kooks.
Thanks! Mike
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock Last edited by STALKER; 05-29-2022 at 11:46 PM. Reason: TITLE |
![]() Drives: 2015 camaro Z/28 Join Date: Apr 2015
I have American racing headers and off road pipes brand new in the box
Black 2015 camaro z/28 #445 with ac
![]() Drives: 15’ Chevy Camaro Z/28 Join Date: Jun 2020
DELETE THREAD....Nothing but scammers on this site anymore.
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
CamaroFans.com
... Thanks for bumping the thread and not reporting them as they move on to scam others.
#6 |
Before you post crap like this and bump the thread unnecessarily, take a second and do some research... I do report scammers however the last time I did, nothing was done. I’ve even made threads on here and Camaro6 warning people about it…Don’t believe me?, look at my created threads under my statistics.
#7 | |
CamaroFans.com
Sorry, but I take scammers seriously and if someone else hadn't reported this one he was already in the process of PMing another user to scam them. It's just as easy to report as it is to post and even easier than creating a new thread about it. |
