Old 05-28-2022, 01:07 PM   #1
PopDeer
PopDeer's Avatar
Drives: Camaro LT 2012
Swapping 21" for 20" rims (2012 LT)
Hello everyone,
I'm looking into replacing my 21" OEM black aluminum 5-spoke rims with 20" rims. The tire options available for the 21" rims are too expensive and it's my understanding that there is a wider and less expensive selection available for 20" tires. I'm by no means an expert when it comes to my car, so I was wondering if anyone could help check my understanding. I have the following 21" rims on my car now: https://www.detroitwheelandtire.com/...7-pbp-a-f.html with 245/40-ZR21 tires on each. I would like to replace these with the black 20" rims that were available with the RS package (maybe it was the Transformer edition). I've been looking at these: https://www.detroitwheelandtire.com/...-pvd-f-ow.html (20 x 8").
Here's a few questions I have:
  1. Will there be any issues replacing the 21" rims with 20"? I would guess going down in size is always safe.
  2. Is it worth buying factory OEM wheels? Are cheaper replicas worth considering? I will be selling my 21" rims to account for some of the cost.
  3. With the 20" rims I was going to go with a square setup of 245/45-20 tires. Any problems with that? Reference: https://www.camaro5.com/forums/showthread.php?t=62838
  4. Do I need any parts besides the 20" rims and new tires?
Thanks so much, I appreciate any advice anyone can offer.
PopDeer is offline   Reply With Quote
Old 05-28-2022, 08:05 PM   #2
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
It’s safe to go to 20” or 22” from the original 21” you had. I had the 21” wheel/tire setup but switched to 22”. 1 thing for sure is an 8” wheel seems quite thin. In front you could run a 9” or 9.5” and in the rear do anything from 9” to 11”. More often ppl seems to run a 9.5/10” search around the forum and you’ll see the different combos available and learn what offset folks have used without tire rubbing issues.
My top pic is 21”
2nd pic 22”
Last pic 20”
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 05-29-2022, 10:33 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Looks good in all the pics, but REALLY great with the 20" Welds!! They really wake up the cars look!! Nice bro. And for the op, the 20's are the way to go. Much more out ther to be had combo wise. And lower pricing.
Old 06-01-2022, 10:43 AM   #4
PopDeer
PopDeer's Avatar
Thanks for the responses! I appreciate it! It’s great to see pictures of the different sized rims, especially including the ones I have! Thanks!
20 inch, 2012, 21 inch, rims
