Old 05-30-2022, 04:46 PM   #1
Dutchman427
Drives: 2012 ZL1 #1329 M6
LSX 454
I got a new in the crate finished LSX 454 block along with everything needed to finish it. PM me if interested.
Dutchman427 is offline   Reply With Quote
Old 05-31-2022, 11:16 AM   #2
Brad7294
Drives: 2010 2SS/RS LS3
Can you post some pictures? Price?
Brad7294 is offline   Reply With Quote
Old 06-01-2022, 02:34 PM   #3
Dutchman427
PM Sent
Old 06-02-2022, 05:21 AM   #4
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
send me info also please
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 06-02-2022, 06:24 AM   #5
Dutchman427
GMPP LSX Front Cover 12633906 -$115.96
GMPP LSX Rear Cover 19369274 -$364.22
GMPP Valley Cover Plate 12599296 -$133.99
GMPP Head Bolt Kit 19257453 -$121.83
GMPP Head Gaskets 19170419 - $196.24
GMPP LSX-LS7 CNC Ported Heads 19419197 -$2,364.18 x2
GMPP LSX 454 Block 19417353 - $3,922.00
GMPP LSX Controller for Manual Trans - $1,500.00
GMPP Front Completion Kit 19299099 - $298.91
GM Cam Bolts 11588723 -$67.92
GM Intake Gaskets 89060413 -$62.96
GMPP Rear Cover Cable Gasket 19166181 -$3.51
GMPP Rear Cover O Ring 19166180 -$3.55
GM Crank Shaft Oil Seal 89060436 - $21.71
GM Intake Rocker Arms 12579615 -$122.08
GM Exhaust Rocker Arms 12579617 -$134.16
GM Cam Bolt 11588723 -$33.96
Callies Dragonslayer Crank 4.125 - $1,605.00
Lunati X Beam Rods- $1,272.00
Mahle 4.185 12.1 Piston Kit - $848.00
Mast Oil Paint Assembly -$564.65
ARP Main Stud Kit 234-5608 -$243.79
LSA/LS9 Valve Covers with Coils/Fill Neck - $560.36
Tony Mamo Cam with Valve Springs and retainers - $600.00
Total- $17,525.16
Everything is new in the packages. I just want to break even on the deal.
Old 06-07-2022, 11:53 AM   #6
JMTmotorsports
JMTmotorsports's Avatar
Drives: 1LE 2ss
Would you sell just the short block?
2015 2SS/RS 1LE
AGP TT, COMP AC 62’s, BTR Cam, Pump/Meth, Fore Innovations LC2/FC3, ID1300’s, Bo White TB, Corsa, McLeod RXT, GFB G-Force II, Tuned at CSP SBE 819/755
JMTmotorsports is offline   Reply With Quote
Old 07-05-2022, 02:51 PM   #7
Dutchman427
Bump.
Old 11-09-2022, 06:40 AM   #8
Dutchman427
BUMP.
Old 02-17-2023, 04:59 AM   #9
Hecticzl1
Drives: Zl1
Pics of valve covers
Hecticzl1 is offline   Reply With Quote
Old 05-30-2023, 06:43 PM   #10
Dutchman427
Engine is in the process of being built. Still for sale.
