Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > ZL1 Parts
Old 06-06-2022, 09:55 PM   #1
427bbv8
Drives: 2008 z06
WTB zl1 go fast parts
Got a 2013 zl1 bone stock looking for the following
Headers or catless down pipe
Cold air intake that will work with stock TB
Injectors 850cc or bigger
DSX flex fuel sensor
DSX aux pump or a BAP
ATI lower balancer overdrive
Grip tech upper pulley
Heat exchanger and tank and pump
427bbv8 is offline   Reply With Quote
Old 06-07-2022, 05:20 AM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
i have a 5" jlt intake and 90mm throttle body. pm me if interested.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 06-07-2022, 09:49 AM   #3
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Keep your stock parts for smog unless you plan on non-op
You'll thank me later.
Mods:
Old 06-07-2022, 11:12 AM   #4
427bbv8
Drives: 2008 z06
I have guys
