![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
What brand 180 Deg Thermostat should I get?
I was just wondering if there is one brand that is better then the other with the 180 Deg Stats, I have heard certain ones are known to fail.
LS3 Motor Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() Drives: 2012 SS Join Date: Dec 2021
I got a 160 Stant. have used them for years without any incident.
2012 Camaro SS
![]() Drives: Chevrolet Camaro Join Date: Oct 2021
What brand and where can I buy one ? part number please , bought several from the parts store and ordered some online and they never fit , for 2013 ss??
I already have a tune ready to load for a 180, I have a 169 on the shelf. I am looking for a 180.
https://granatellimotorsports.com/i-...es-53080s.html
https://briantooleyracing.com/motora...9-523-180.html https://www.lingenfelter.com/product...l#.YqCWBuzMJEY Lingenfelter is 174, My Tune I have ready to load is for 180 Deg stat with fan settings, not sure if the 174 is to low, or if any of the other links are good replacement items. I have heard the Mishismoto are hit or miss.
#6 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I went with an OE Z/28 158* thermostat 12661950
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
#7 |
I think that would be a touch to low for me, I went with a 180 Hi FLo by Motorad which is what th vendors above all carry.
#8 |
![]() Drives: Chevrolet ZL1 Join Date: Feb 2025
The Granateli and the Motorad both look like $7 auto store quality compared to the OEM. Both the Motorad 174F and the Granateli 180F thermostats both ran hotter than my OEM 187F!
#9 | |
GPI Sales Consultant
Summit branded 160*F stat has treated me well. I liked the Misimoto 169*F for a while, but after having two fail I went back to the trusty generic one from Summit and it's been good. That's what we sell here at GPI, and I haven't had come-backs on those, so they have my confidence.
As far as the 180 vs. 160*F - why not the 160*F I'd be interested to learn your concerns with going to the 160*F. There are a lot of common misconceptions on thermostats, how they function, etc. I've got a video with some information that you might find helpful/interesting:
Got a question about a GPI product? Feel free to shoot me a message! |
#10 | ||
I am running the Mishi 169* one Acammer mentioned here and its has been going great for the past 2 years. If I remember correctly, the rubber seal on the earlier mishi ones would fail. Looks like they fixed that issue since.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
#11 | ||
#12 | |
The 169*F is great in a bolt on car that doesn't produce much heat, but with a cammed setup I have found the 160*F doesn't over-cool, and provides more initial thermal capacity that suits my drag strip needs best.
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
