Old 06-16-2022, 06:58 AM   #1
Surfdog SS
Surfdog SS's Avatar
Drives: 2015 SS Black/Black
Catch can
What are you guys using for catch cans? I have a Novi 1500 kit that came with a Jegs oil separater. Looks pretty crappie and I would like to clean it up with something else.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, dsx aux pump and flex fuel, monster triple disc.
Surfdog SS is offline   Reply With Quote
Old 06-16-2022, 07:44 AM   #2
gtstorey
Mighty Mouse
Old 06-16-2022, 10:15 AM   #3
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
Elight Engineering.
sscamaro is offline   Reply With Quote
Old 06-16-2022, 10:25 AM   #4
Mr2Hard2See
Instagram: Mr2Hard2See
Mr2Hard2See's Avatar
Drives: 2011 2SS/ RS
Mighty Mouse wild catch but these are pricey I’m lucky I bought mine used from my buddy
YOUTUBE CHANNEL: Mr2Hard2See
LSA blower BTR stg 2 cam 227/242
BTR dual springs pushrods lifters retainers etc
Che bronze trunnion Ls3 timing/valley cover
Dod/vvt delete Dsx e85 Dsx aux fuel pump Id1050x injectors ZL1 fuel pump, Griptech 2.55 pulley, Solo performance Mach ll 2.5 catback exhaust 1 7/8th Lt headers
Mr2Hard2See is offline   Reply With Quote
Old 06-16-2022, 04:04 PM   #5
Little Walter
Drives: ZL1
I use the J&L 3.0 and it definitely works.
Little Walter is offline   Reply With Quote
Old 06-16-2022, 05:28 PM   #6
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Motion
joshnmn is offline   Reply With Quote
Old 06-16-2022, 06:38 PM   #7
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
ADD W1
0stones0 is offline   Reply With Quote
Old 06-16-2022, 06:44 PM   #8
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Boosted application I would go with Mighty Mouse.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 06-16-2022, 06:51 PM   #9
KnoxSS1LE
Drives: 2013 SS1LE
Motion RaceWorks. Catch can and valve covers. Little pricey but quality is top notch.
RotoFab intake, Nick Williams TB, LOD intake manifold, LOD fuel rails, Injector Dynamic 1050cc injectors, ceramic plug wires, Frankenstein M311 heads, BTR trunion upgrade, Cam Motion custom cam, Ls7 lifters, Ls7 timing chain, Melling HV oil pump, Lingenfelter thermostat, Setrab oil cooler, Setrab LS oil cooler thermostat, Stainless Works 2" headers, Corsa 3" catback, KW V3 coilovers, Detroit Speed control arms, Detroit Speed camber arms, Detroit Speed trailing arms, Detroit Speed cradle bushings, BMR upper control arm bushings, E-85, Motion RaceWorks valve covers and catch can
KnoxSS1LE is offline   Reply With Quote
Old 06-17-2022, 04:21 AM   #10
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Elite Engineering for the absolute most effective design on the market period. Test and see first hand:
Sales@EliteEngineeringUSA.com and for pre sale questions and all things technical: Tech@EliteEngineeringUSA.com
Elite Engineering is offline   Reply With Quote
Old 06-17-2022, 08:08 AM   #11
RupertPupkin
Drives: 2014 Camaro SS 1Le
Mighty Mouse…
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 06-17-2022, 08:40 AM   #12
Elite Engineering
Drives: 2010 Camaro
Elite Engineering...
Old 06-18-2022, 11:29 AM   #13
Beefsquatch
Beefsquatch's Avatar
Drives: 2010 LS3 camaro
I use elite engineering for n/a and its been solid for years. Now that the car is apart for boost i bought a dual outlet with check valves. quality parts.
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
Beefsquatch is offline   Reply With Quote
